Login to post Forums » Grassroots Motorsports » the new 4x4 beater, possible ZAV
  • patgizz
    Nov. 6, 2011 6:28 p.m. patgizz SuperDork
    i gave up on the monster 3/4 ton 4x4 v8 astro after the frame blew up with rot from the inside out. i needed a reliable semi daily child safe 4x4 with cheap parts. this one only has possible ZAV status because you can't blink without seeing one, so after the apocalypse there will be spare parts everywhere, and parked the zombies will assume nobody is inside. so without further dudes i present my new $900 96 blazer:
    took the impala ss to pull a part for a turn signal switch and grabbed this:
    with my mom's 97
    it has 114k and i have already fixed non functioning interior lights, replaced turn signal switch, shampooed interior, installed tire carrier. tomorrow's plan is new idler arm, top hinge pin/bushing on drivers door and fix boned up striker from said door pin being shot, and hopefully dig a radio harness out of somewhere since some dong cut it instead of splurging for a $4 adapter plug. picked up a bravada front bumper, and going to do a 2" shackle/torsion bar crank lift to clear some 30.5" tires i have laying around because it's rolling on 4 different tires right now.
    and heres a screenshot of my speedo from the pull a part run in the SS at 8am, ignore top speed and pretend i was on a track.
    more likely, the best possible ZAV pulled home the blazer. 8mpg ftw.
  • irish44j
    Nov. 6, 2011 6:52 p.m. irish44j Dork
    I'm thinking that tow vehicle would make a much better ZAV. That big flatbed is perfect for mounting multiple heavy machine guns with a full field of fire.
    EDIT: didn't notice you already said that at the bottom!
  • SyntheticBlinkerFluid
    Nov. 6, 2011 7:21 p.m. SyntheticBlinkerFluid Dork
    My mom had a '95 Blazer. It was pretty reliable. I sometimes miss that truck in the winter.
  • patgizz
    Nov. 6, 2011 8:20 p.m. patgizz SuperDork
    that's my big truck. i love that thing, i towed 4 cars to scrap thursday and friday then took it on a 150 mile round trip saturday to get the blazer. the big block makes me smile.
  • corytate
    Nov. 6, 2011 8:40 p.m. corytate HalfDork
    my dad has one from around that time, pretty reliable, but his fuel pump just crapped out. 250ish dollar part sadly
  • patgizz
    Nov. 7, 2011 8:34 p.m. patgizz SuperDork
    today consisted of installing new idler arm and 245/45/16 wrangler ht tires on some firebird rims. also fixed the door hinge pins and torn out latch striker. next up is a tune-up/fuel filter and fixing the hacked up radio wiring so i can put my head unit in. also need to lift a little bit because i get a little tire rub on my front right fender.
    bought a bravada front bumper but might build something with a winch mount because one of the duties of the blazer will be going into the woods for firewood.
  • CarKid1989
    Nov. 7, 2011 8:56 p.m. CarKid1989 Dork
    well i saw the blazer today. looks great. good buy
