Login to post Forums » Grassroots Motorsports » The UnSpecified Miata (part deux)
  • Woody
    Nov. 11, 2008 8:54 p.m. Woody Dork
    It's time for another update on the deconstruction of my Miata. The original thread was getting a little heavy with photos, so I decided to start another one. Here's a link to the original for reference:
    http://grassrootsmotorsports.com/forum/grm/the-unspecified-miata/4332/page1/
    I've made some real progress over the past few days. Sunday began and ended with the two cars looking pretty much the same.
    Photobucket
    However, over the course of the day, they exchanged exhaust systems. The job went fairly smoothly. The Spec Miata system on the green car came off easily, as I've swapped between the catalytic converter and the race pipe several times over the past few years. I also sprayed the bolts on the black car's stock system with PB Blaster and let it soak for a few days while I worked on other stuff, so everything came right off, even the O2 sensor.
    Photobucket
    As they say, "Installation is the reverse of removal", with one exception: The Spec Miata system has no provision for the downstream O2 sensor. I don't have a photo of it, but I bolted the sensor to the outside floor of the car with a hose clamp to keep the check engine light from coming on. The upstream sensor works normally and the downstream sensor is fooled into thinking that you have the best catalytic converter in the world , as it is exposed to clean, outside air. It needs to be outside the car as it's a heated sensor and it gets hot enough to burn your flesh badly (ask me how I know), so parking on the grass is no longer an option. At some point, I will remove the cat-back and have a sensor bung welded in there to keep things legal. I do have the stock cats on both cars now; the system is really, really loud with the race pipe in place of the cat.
    Photobucket
    I spent about two hours on both swaps, so I'll split the time and just charge one hour to the green car project, bringing the total to 19.5. The exhaust swap was a major step, as the car was now quiet enough for some road miles. I took a trip to Home Depot and ran a few other errands with it. It was a lot of fun, in spite of the fact that it still had the stiff springs in it.
    I spent some time on the black car as well. Besides the exhaust, I swapped on the bigger sway bars and it grew a chin spoiler in front. That car now goes back into the corner while I finish up the green one.
  • Woody
    Nov. 11, 2008 9:33 p.m. Woody Dork
    After driving the car around town for two days, I decided it was time to get back to work.
    I wanted to reinstall the soft top assembly, but things didn't go as planned. I got it out of my attic and in the course of getting tools ready, I discovered two large tears in the top. I must have done it when I removed it, as I only remember one small tear that I had patched. The top wasn't beautiful to begin with, and I really didn't feel like reinstalling it anyway. The plan for now is to leave it off and include the hard top when I sell the car. The next owner can install a new top on the old frame if he or she chooses to. I've gotten the convertible thing out of my system and I always liked driving these cars with the hardtop on. And not having the folded soft top under there frees up a bit of usable space on the rear shelf. I think it looks good, too.
    So, I moved on to the suspension, ahead of schedule. I removed the Bilstein/Eibach/Ground Control combos and replaced them with a set of low mileage originals. I was pleased to see that the original boots were still in good condition. I had bought another set of stock shocks from a fellow GRM'er, but that was before I found my 36,000 mile parts car. That allowed me to get an extra set of stock springs and hats, which saved me a ton of time.
    Photobucket
    Photobucket
    The first front shock took nearly an hour, the second, about twenty minutes and I did both of the rears in less than half an hour. Keith's book was very helpful. The job wasn't bad at all. When I installed the suspension a few years ago (including all new Mazda bushings), I bead blasted all of the bolts and coated everything with anti-seize. Couple that with the fact that this was originally a Southern car and that resulted in easy work.
    When the front of the car was up in the air, I drained some coolant and swapped in a new upper radiator hose, reclaiming the split hose with the aftermarket temperature sensor, and then replaced the coolant.
    Photobucket
    I also took a moment to reflect upon the hidden cost of racing: Cable ties.
    Photobucket
    Now the car sits on stock suspension again, the bolt-in roll cage is gone and the interior is back to stock. I still need to get it aligned and find a used hood latch assembly, as the one the one I bought last week is no good.
    Then, I'll drive it until the snow begins to fall. When Spring rolls around, I'll pull it out of the garage, dust it off and slap some For Sale signs on it.
    Once I get it back from the alignment shop, I'll give it a bath and take some photos of the end result.
    Total time: About 23 hours.
  • Woody
    Nov. 16, 2008 6:58 p.m. Woody Dork
    Final Update:
    I got the car cleaned up and snapped a few photos of the final product.
    Photobucket
    Photobucket
    Obviously, the hood pins had to stay, as there is no good option for removing them. I plan to fully disclose the car's history to anybody who may be interested in it anyway.
    I got the car aligned last Thursday and I pressed it into duty as my daily driver. I'm enjoying the crap out of this car! I've owned at least one Miata for the last eight years, but they were always reserved for sunny days or HPDE's; I forgot how much fun they can be day in and day out. The plan now is to continue to enjoy it until the snow falls or it finds a new home.
    Overall, the deconstruction went smoothly and was much quicker than I had anticipated. The experience will also help me when it comes time to set up the other car.
    Time to go for another ride!
  • pigeon
    Nov. 16, 2008 7:06 p.m. pigeon Reader
    Nice work. Is it just me or is that car sitting awfully high?
  • Woody
    Nov. 16, 2008 7:59 p.m. Woody Dork
    It just came off the jacks and hadn't settled down onto the suspension yet when I took those photos.
  • Woody
    Nov. 18, 2008 7:49 p.m. Woody Dork
    Berkeleying deer.
    Photobucket
