Login to post Forums » Grassroots Motorsports » This one ain't for the purists « 1 2 »
  • patgizz
    March 16, 2010 2:02 p.m. patgizz SuperDork
    thats a giant bag of awesomeness
  • nocones
    March 16, 2010 2:04 p.m. nocones Reader
    I want to know more about the front roll bar. . (the watts link looking thing in the front). The way it looks like it works, it just resists all roll. This is not the best, so I'm thinking there is something more to it than that. The way It appears the only way it could work and allow roll is if the crank in the middle moves side to side during cornering. The bracket it is attached to has quite a few bolts in it, so it's possible that this is the case. Anyone have more pictures or insight to a anti roll bar linkage like that?
  • pinchvalve
    March 16, 2010 2:24 p.m. pinchvalve UberDork
    Where?
  • 96DXCivic
    March 16, 2010 2:26 p.m. 96DXCivic HalfDork
    In reply to nocones:
    That is a pretty standard setup of an anti-roll bar on a pushrod setup. If you look at Formula SAE, you will see several setups like that.
  • 96DXCivic
    March 16, 2010 2:27 p.m. 96DXCivic HalfDork
    In reply to pinchvalve:
    Look at the second picture in the original post. It is connected to the bellcranks.
  • WilberM3
    March 16, 2010 5:37 p.m. WilberM3 New Reader
    looks like instead of adding another spring (bar) it just uses the inside corner's spring against the upward motion of the outside's. looks a lot lighter and you wouldnt have an ugly swaybar hanging off the bottom of the suspension
  • Appleseed
    March 16, 2010 7:52 p.m. Appleseed Dork
    There hasn't been a pure 32 since John Milner was killed. And even his 32 wasn't proportioned right. There is nothing wrong on a 32 because everything's been done to a 32. I see nothing wrong with that car.
  • GPDren
    March 16, 2010 10:30 p.m. GPDren New Reader
    I love the car and I love that you guys do too. Not too many snobs around here are there?
  • nocones
    March 17, 2010 12:38 a.m. nocones Reader
    Ahh, I see. In one wheel bump it actually tries to pull the other wheel off the ground. Or put another way during cornering it doesn't allow the other wheel to droop. Basically it transfers all the load to the outside tire. It allows for no roll. I really thought it was more exotic than that. It sounds less than Ideal. We were going to use it on our FSAE car, but we had tested that that type of ARB and did not like the way it made the front end very suseptable to straight line instability. I'm fairly certian formula fords use that type of ARB so obviously it can be made fast. I thought maybe this guy had done something new and different. I mean with that particular thing, the car is amazing, I just was wondering about the ARB.
  • mtn
    March 17, 2010 12:53 a.m. mtn UltraDork
    You must be new here. Lets see... Off the top of my head, I can think of people here who put a diesel in a miata, a subaru engine in a porsche, a rotary in a spitfire, a SBC in an E30.... the list goes on.
  • Appleseed
    March 17, 2010 1:18 a.m. Appleseed Dork
    I'll amend that to "SBC in an anything."
  • neon4891
    March 17, 2010 7:53 a.m. neon4891 UberDork
    Volvo is part of Ford, for now atleast, so it is still "in family"
    I approve
  • ultraclyde
    March 17, 2010 9:20 a.m. ultraclyde Reader
    I wondered why the volvo, then I saw Sweden. Oh. I love this kind of thing. I've dreamed of building a lightweight fiberglass highboy 32 with an sr20det or stook drivetrain. Then hoon it to maximum effect.
  • JoeyM
    March 17, 2010 9:20 a.m. JoeyM Reader
    I approve
    The swap done the other way - ford powerplant into a volvo body - works too. Don't forget how fun Greg's volvo station wagon with the mustang drivetrain is.
  • tuna55
    March 17, 2010 9:28 a.m. tuna55 HalfDork
    Want one, badly. What's cool is that the second car pictured, if I remember, is actually a Volvo anyway!
  • turboswede
    March 17, 2010 11:39 a.m. turboswede UltraDork
    Looks like it would work like a regular ARB would, both solutions try to correct the body roll by pulling upwards on the inside wheel in a corner. The difference is that on the car here and other cars as describer, it is a solid link versus a solution with a specific spring rate applied to it.
  • plance1
    March 17, 2010 9:12 p.m. plance1 HalfDork
    purists suck
  • MrJoshua
    March 17, 2010 9:45 p.m. MrJoshua UltraDork
    Ive been involved in 2 out of 4.
« 1 2 »
