Toyman01
Toyman01 MegaDork
9/10/18 3:45 p.m.
How much clearance is needed between the tire and the upright? The new wheels came in for the G35 and they might be a little bigger than I thought.
I only have about 3/8" clearance between the wheel and the upright. The tire may be a little closer once I get them in. How tight can it be.
Next question. How close can it be to the calipers. Looks like it will be about 1/8" These are not sliding calipers so that clearance shouldn't change other than whatever flex is in the assembly.
wvumtnbkr
wvumtnbkr UltraDork
9/10/18 3:55 p.m.
I'd say your fine.  We run that much space on our champcar.  Never had a problem.
Especially with short sidewalls.
mazdeuce - Seth
mazdeuce - Seth Mod Squad
9/10/18 5:59 p.m.
I agree that it'll probably be fine. Do you have enough stud to throw on 1/4 inch spacers? The wheel clearance will work but the tires might want a little breathing room.
Toyman01
Toyman01 MegaDork
9/10/18 6:07 p.m.
In reply to mazdeuce - Seth :
I ordered two sets of 5mm spacers just in case.
tr8todd
tr8todd Dork
9/10/18 6:19 p.m.
What you just described is pretty much every TR8 that has upsized to 15X7 wheels and big brakes.
ultraclyde
ultraclyde PowerDork
9/10/18 6:32 p.m.
Yeah, I've seen less clearance on other cars without an issue. Unless you run tall tires and pull a ton of Gs you should be fine.
mazdeuce - Seth
9/10/18 7:10 p.m.
And excellent wheel choice too. laugh
Toyman01
Toyman01 MegaDork
9/10/18 8:16 p.m.
Cool. The bronze wasn't my first choice in color, but that was all they had in a 9" wheel. Now that they are here, I'm really liking them.
mazdeuce - Seth
9/10/18 8:25 p.m.
Same reason I have bronze, but like you, I kinda dig them.
ProDarwin
ProDarwin PowerDork
9/10/18 8:37 p.m.
For a strut car, a credit card width is fine.
Usually on a DWB car the control arm hits the inside lip of the wheel (at/near full lock) before you run into upright clearance issues.  (see:  Miata)
GameboyRMH MegaDork
9/11/18 10:14 a.m.
This. For brake to wheel clearance, you only need to account for flex and thermal expansion, which is approximately nothing.
wspohn
wspohn Dork
9/11/18 3:55 p.m.
Depends on how hard you drive.  I had some tires on my TVR race car once with 1/2"clearance between tire and rear upright.  Ripped the sidewall out in the first hard lap - they sometimes flex more than you expect.  And I was running higher than street pressures, too.
7uaq0x11IW8TZM0h88FL0qMu9AR6Hh9UDxANAHNUIhQ3wK5mJYejOLDBgto17xwn
