Login to post Forums » Grassroots Motorsports » towing a astro van
  • Nov. 19, 2011 2:46 p.m. gemgirl None
    I would like to tow a astro van behind my RV. Does it need a driveshaft disconnect? Any thoughts or info would be appreciated.D.
  • pinchvalve
    Nov. 19, 2011 4:27 p.m. pinchvalve SuperDork
    2WD or AWD?
  • Toyman01
    Nov. 19, 2011 4:28 p.m. Toyman01 SuperDork
    Automatic transmissions usually need to have the driveshaft dropped to tow them any distance. I would say, yes.
  • Nov. 19, 2011 4:31 p.m. EvanR Reader
    Unless you have one of the rare 5-speed Astros. Those can flat-tow.
    But if you have one, I'm coming to steal it.
  • Vigo
    Nov. 20, 2011 7:29 p.m. Vigo Dork
    You can probably get one of those external trans fluid pumps that gets power from the RV when you plug in your lighting (etc) connector.
    But yes either a regular 2wd or AWD would need either that or a disconnected rear driveshaft to be flat-towed.
  • May 17, 2012 11:42 p.m. Billybob
    For anyone still interested I towed an Astrovan with automatic transmission for approx. 9000 milesover last two years without any problems. For trips of up to a couple of hundred miles, I would stop about 80 miles or so and start the engine, then run through the gears, stop engine, leave in neutral and resume trip. For longer trips. I simply cut a 10 by 10 in. hole in the floor over the u joint and removed the four bolts from the inside.I welded two hinges on the trap door and a tap for a screw to secure it down .It works great. Ten minutes extra to hook up is way less costly than a trans. pump or driveshaft disconnect.
