Login to post Forums » Grassroots Motorsports » Ugly but functional body work?
  • Tyler H
    Feb. 28, 2011 9:16 p.m. Tyler H Dork
    I need to pull out some damage my lemons candidate and could use some suggestionson how to start. I have naive notions of building it nice enough to get a logbook, so no radical sawzall treatment, if I can avoid it.
    Car in question is a 95 Civic that took a ride into a barrier on the drivers side, the door still functions and a new one will bolt on. The jamb/stiker is okayish. The panel from the jamb to the rear wheel and under the window is crushed in. It wasn't hard enough to break glass, but there is a tire clearance issue, which is the big concern.
    So what is the best way to pull this puppy out?
  • oldtin
    Feb. 28, 2011 9:23 p.m. oldtin Dork
    can you reach it from inside and knock it out - BFH city? Other wise slide hammer - the weld on studs work nicer than screws through the body. It's the reverse BFH. Either way the answer is hammer short of new panel.
  • John Brown
    Feb. 28, 2011 9:23 p.m. John Brown SuperDork
    Son, that is a Lemons "character line". Leave it.
    You don't spackle in the cleavage because the breasts are large, do you?
  • Zomby woof
    Feb. 28, 2011 9:34 p.m. Zomby woof Dork
    Sometimes you put a little filler in....
  • bluej
    March 1, 2011 8:10 a.m. bluej HalfDork
    thanks, I made it almost all winter without getting coffee on this fleece pullover.
  • 44Dwarf
    March 1, 2011 9:28 a.m. 44Dwarf Dork
    Push it out from the inside then spray the out side with carpet glue and hang green indoor outdoor carpet on it! I remember seening a large caddy with real grass growing on it as a kid. Hail damaged car i was told so owner spot welded on chicken wire then laid down sod and watered it.. Man that was funny.
  • Tyler H
    March 1, 2011 4:39 p.m. Tyler H Dork
    I can get to some of it from the inside. It is more than a character line. The tire and body want to occupy the same space at the same time. I was thinking about welding some studs on it and pull it with my truck. Maybe I underestimate myself, but a slide hammer doesn't seem like it would have enough umph for this.
    I mean, it was a hard enough hit to make a 95 Civic cost less than $500, if that tells you anything. Of course, it came without an engine.
    I may do a before and after shot.
  • March 1, 2011 4:54 p.m. triumph5 Dork
    Cut out metal in the way; 'glass in masonite; paint and compete!
  • Keith
    March 1, 2011 5:09 p.m. Keith SuperDork
    Sawzall, then rivet in some street signs.
  • pilotbraden
    March 2, 2011 8:38 a.m. pilotbraden HalfDork
    Too bad the grass was not on a Mercury Marquis. It would be the Marquis de Sod
  • ReverendDexter
    March 2, 2011 9:04 a.m. ReverendDexter SuperDork
    In reply to pilotbraden:
    That's straight up genius, sir.
  • ransom
    March 2, 2011 9:15 a.m. ransom New Reader
    Brilliant. That's a properly painful pun.
    I had an '84 Marquis, for which I had a little "de Sade Edition" sticker made up to go under the badge...
  • GameboyRMH
    March 2, 2011 1:03 p.m. GameboyRMH SuperDork
    Hey if it's circle-track racing you can fill it with lead, depending on which side it's on
  • GameboyRMH
    March 2, 2011 1:04 p.m. GameboyRMH SuperDork
    He was ahead of his time, he made the world's first green car!
  • dj
    March 2, 2011 1:06 p.m. dj Reader
    http://www.marquisdesod.com/
