I went to swap out the Hawk Blues from my last track day - the front passenger side pads are worn almost to the backing plates - the front drivers side pads are only ~ 25% worn.
I also have recently developed a soft pedal - there are no leaks (in the calipers or the lines) - I'm thinking this problem is a bad master cylinder.
So what's the problem? I'm thinking either: 1. sticking caliper. These are rebuilt calipers, only around 5,000 miles and a year's use on them. 2. Bad master cylinder causing uneven hydraulic pressure...or... 3. Both.
I'm replacing the MC and rebuilding all calipers, just curious if anyone has come across this?
