Login to post Forums » Grassroots Motorsports » V-DUB HELP
  • Jakeinthepaddock
    Oct. 9, 2008 6:06 p.m. Jakeinthepaddock None
    Hi I was wondering about trasmission on 97 jetta I've taken all the bolts out and drive plates 2 times can only get a small gap on the case got a self inflected prodlem on one of the shift forks. Anybody know where the seceret button is? thanks Jake...
  • fifty
    Oct. 9, 2008 8:19 p.m. fifty None
    What transmission code is it? I had the same problem on a manual trans 1992 VW a couple of nights back (020 family of transmissions). I ended up reading the Bentley manual, the engine needs to be at TDC. There is a mark on the flywheel for TDC. Try it and report back!
  • Jakeinthepaddock
    Oct. 15, 2008 7:19 a.m. Jakeinthepaddock New Reader
    Hey . fifty Maybe I should be more clear Trans is out on bench.all bolts are out of trans body. need to split case. any ideas? thanks jake..
  • RXBeetle
    Oct. 15, 2008 9:01 a.m. RXBeetle New Reader
    Should be an 02A (check the code right next to where the starter bolts up This might help http://forums.vwvortex.com/zerothread?id=767717
  • 16vCorey
    Oct. 15, 2008 11:10 a.m. 16vCorey Dork
    Only if it's a VR6. A 4cyl is going to have an 020.
  • fifty
    Oct. 15, 2008 7:29 p.m. fifty New Reader
    http://www.brokevw.com/
    "Broke" on the VW Vortex manual transmission forums has helped me in the past - you might try sending him a PM, or posting a thread there.
    Edit - let me know how you make out with it - I have a "2Y" trans that I want to put an LSD in in the next couple of months.
