Login to post Forums » Grassroots Motorsports » vw head swapping ?
  • Spinout007
    Oct. 6, 2010 10:14 a.m. Spinout007 Dork
    Can you bolt on a 16valve head to an 8v block? Or should I just boost the bejezus out of the 8v? Or would the hot ticket be 16v and boost? Realized I need more power at the challenge. Much More power.
  • SVreX
    Oct. 6, 2010 10:19 a.m. SVreX SuperDork
    Yes, yes, and yes.
    I'm on the same subject. Some of the VW gurus have already weighed in. Follow thread here:
    SVreX's VW power thread
    I have no idea why I started that thread in Off Topic.
  • ansonivan
    Oct. 6, 2010 10:20 a.m. ansonivan HalfDork
    16v head onto aba block is a common swap for boost, it does require a little fiddling but it's still cheap and easy. Compression does end up being a little low for non-turbo applications.
    Might be simpler to just ad another engine.
  • 16vCorey
    Oct. 6, 2010 11:00 a.m. 16vCorey SuperDork
    The short answer is, if you want to go N/A, find a junkyard Passat and put a 2.0l 16v in it. If you want to boost it, stack some head gaskets on a stock 16v or do the ABA/16v hybrid. Or just use E85 and Megasquirt it, and boost the crap out of what you've got.
