Login to post Forums » Grassroots Motorsports » Want an Atom?, build your own
  • aircooled
    Sept. 26, 2008 6:43 p.m. aircooled Dork
    http://blog.wired.com/cars/2008/09/gearhead-builds.html
  • Hasbro
    Sept. 27, 2008 2:53 a.m. Hasbro HalfDork
    http://grassrootsmotorsports.com/forum/grm/homemade-ariel-atom/3360/page1/
  • walterj
    Sept. 27, 2008 8:09 a.m. walterj HalfDork
    OK... so I'm intrigued. How do you make those long huge radius bends if saaaay you were thinking "Wow, that looks way cooler than the Locost I was planning"?
  • oldopelguy
    Sept. 27, 2008 9:13 a.m. oldopelguy HalfDork
    Usually those are made with a bender that has three rollers, one on top and two on bottom. The tubing is fed into the rollers and tension is out on the top one pressing it down betwen the bottom ones. Then the tube is fed through the rollers back and forth until it has enough of a constant bend that it removes the tension. If more curve is needed, the top roller is adjusted again.
    Eastwood sells a decent one, though theirs may not maintain a perfectly round profile in crosssection.
  • Travis_K
    Sept. 27, 2008 6:33 p.m. Travis_K Reader
    Im not too sure about the "roll bar" but the rest of that looks pretty nice.
  • neon4891
    Sept. 27, 2008 11:19 p.m. neon4891 Dork
    any thing that small and that fast is sick. but i think a turbo/westfeild body miata would give it a run for its money and be cheaper
