ebonyandivory
ebonyandivory PowerDork
11/19/18 2:27 p.m.
Is uncleared waterborne paint able to be washed off with water?
Example: if it rained on your dried but uncleared car painted with water soluble paint, would it run off?
Ranger50
Ranger50 UltimaDork
11/19/18 2:42 p.m.
Don’t believe so as the water is the solvent vs voc’s. Once paint is dried/cured, it would require a paint stripper to remove just like regular paint would.
aircooled
aircooled MegaDork
11/19/18 3:01 p.m.
I am pretty sure all house paint is now water based...
But yeah, painting something with enamel where it rains paint thinner does seem strange.
ebonyandivory
11/19/18 3:08 p.m.
My son is in a collision repair class at school and was trying to tell me until the car is cleared, the paint can simply wash off with water.
I disagree
NOHOME
NOHOME UltimaDork
11/19/18 3:59 p.m.
Nope, not going to wash off:
Water-bourne paint still polymerizes the same as chemical paint is is just that water is used to make it "watery" enough to spray and self-level.
That said, since there is a clock running on how long you can wait to clear-coat the base coat. I cant see where water would ever be involved? Usually around 24 hours.
The constituents of paint
Paints contain:
  • pigment(s) - prime pigments to impart colour and opacity
  • binder (resin) - a polymer, often referred to as resin, forming a matrix to hold the pigment in place
  • extender - larger pigment particles added to improve adhesion, strengthen the film and save binder
  • solvent (sometimes called a thinner) - either an organic solvent or water is used to reduce the viscosity of the paint for better application. Water-borne paints are replacing some paints that use volatile organic compounds such as the hydrocarbons which are harmful to the atmosphere.
zKdjTyJcwimVU7xvne4XTiEY9CcqhbWXv8t4DtluagTArvSq53KfzYIc8I0bRt57
