6/10/20 11:00 p.m.
If I use the SBC side mounts on MonZora, I'll need to DIY them for budget. I think I want some kind of bushing in there. What are you guys using for cheap, stiff but not too stiff, round bushings with weldable shells?
SkinnyG (Forum Supporter)
SkinnyG (Forum Supporter) UberDork
6/10/20 11:08 p.m.
I know many guys use Jeep leaf spring eye bushings.
I just buy Energy Suspension 4-link bushings, and cut tubing.
barefootskater
barefootskater UltraDork
6/10/20 11:26 p.m.
Came here to say the same thing. Used leaf spring bushings in my challenge car.
gearheadE30
gearheadE30 Dork
6/11/20 7:44 a.m.
Oh man, that's a great idea.
Not weldable shells, but I always have used BMW E30 engine mounts since they are cheap in both rubber and polyurethane form and are the stud style that lets me run a plate on the bottom and another on top adapted to whatever engine I have in there. Currently have a set installed in the LS1 944 but haven't actually run it yet. I'm not sure that fits the "stiff but not too stiff" criteria as the rubber would probably be too soft and poly might be a bit much.
Patrick (Forum Supporter)
6/11/20 7:50 a.m.
leaf spring bushings tend to fit in a 1.75 roll cage tube cutoffs.
DeadSkunk  (Warren)
DeadSkunk (Warren) PowerDork
6/11/20 11:20 a.m.
I'll be using Miata A-arm bushings just because that's what I have for a zero budget hit. I'll use two at the motor and two for a transmission mount, too.
wvumtnbkr
wvumtnbkr GRM+ Memberand UberDork
6/11/20 11:27 a.m.
I use hockey pucks with a hole drilled through them.
Stefan (Forum Supporter)
Stefan (Forum Supporter) GRM+ Memberand MegaDork
6/11/20 11:35 a.m.
You can also buy pourable urethane from McMaster-Carr that is decently stiff and pretty damned cheap.
Make the mold from waxed paper and cardboard or similar, embed the necessary bits, mix and pour.  Done.
That said, hockey pucks are nearly free if poke around some of the hockey rinks or groups.
Robbie (Forum Supporter)
6/11/20 11:37 a.m.
In reply to wvumtnbkr :
I'm sure you could hole-saw a hockey puck as well to fit in a specific tube.
Curtis73 (Forum Supporter)
6/11/20 11:45 a.m.
Another cheap option is to get some used Marine mounts from a wasted/free boat.  I like them because they are highly adjustable left/right and up/down.  For custom installs, I can weld in a place for them to mount using a tape measure, then fine tune driveline angle and clearances with the adjustments.
Amazon.com: MARINE POWER Front Engine Motor Mount - 3/4" Replaces ...
wspohn
wspohn Dork
6/11/20 12:38 p.m.
I just welded up some steel brackets that we welded onto the frame and used Jaguar doughnuts to mount the GM V6 in my rebodied MG.
RacetruckRon
RacetruckRon GRM+ Memberand HalfDork
6/11/20 1:13 p.m.
Let me dig through the random bin I might have something that you might be able to make work.
6/11/20 2:20 p.m.
In reply to RacetruckRon :
that would be very cool, thanks!
6/11/20 2:21 p.m.
i've never seen those before.  shouldn't be too hard to find, as there's lots of marinas here in the Detroit area.  we are surrounded by some Pretty Good Lakes.
alfadriver (Forum Supporter)
alfadriver (Forum Supporter) MegaDork
6/11/20 2:44 p.m.
I was thinking the same thing- and AC is in Hockeytown.
RacetruckRon
6/11/20 3:06 p.m.
You've got mail.
6/11/20 3:23 p.m.
received, pondered, replied.
Jeep YJ leaf spring bushings Poly, of course.
1.25" ID/1.5" OD (ie 1/8" wall) pipe cut to 2.58" long fits really snugly.
6/11/20 6:04 p.m.
Don't be a wuss. Solid mount that bitch for maximum harshness.
wawazat
wawazat Dork
6/11/20 7:06 p.m.
Yeah it’s behind you.  Hardtail that SOB!
6NnEjJ7vlyyQqnU1zSSlWELuTqjL5P0JWsUgh0V8a3MlgIQMPUrPSXSlIlDaPgsM
