Keith wrote:
For Targa Newfoundland, you're only allowed to have six tires. So you only need two more $600 wheels for that
You can get adapters to change bolt pattern, they tend to be 25mm thick. So if there's a good source of wheels with a low offset and a more common pattern (such as 5x114.3), then that's a decent way to go.
My understanding with the spacer/adapters is that I will have to either run shorter studs or cut my studs down, thereby rendering my existing wheels (track and winter wheels) useless. I'd rather not consider the Works a sunk cost because they are awesome, awesome wheels. Is there some way I can run adapters AND still retain the use of my other wheels?
Keith wrote:
Shaving 1/2" off the width of the wheel isn't really an option. You can't shave off the outer lip, so you'd have to cut the wheel in half and reweld.
I know a company that does this and has been doing it for years with no problems. It's something I've kept on the back burner for a while now...
