So I have a bit of an oddball car/project looming.........
I have a 77 Puma GTE. Imported from Brazil, it's fiberglass bodied but has aircooled VW mechanicals underneath.
I got the car just to hoon around in as-is. For some reason, that only lasted about a year or so and one day I found myself in the garage with the car up in the air and the engine out of the car! I think the reasoning was I was going to do a little rewiring in the engine compartment. Why I thought to myself that I needed to pull the engine to route about 8 wires is a little hard to explain after-the-fact....
...anyways.
Once the motor was liberated and I saw how a VW swing axle rear responds to camber changes (answer: not really well), I decided to convert the car from swing axle over to IRS. Well, as long as we're doing the axle conversion, and 944 trailing arms can be used as part of the conversion (to get rear disk brakes, too!), I can also convert over to Porsche wheels. I have the 944 trailing arms and am in possession of a set of polished Fuchs wheels. Wheels are 16 x 6, 36mm offset and as of now, are not clearing the calipers by maybe 1/2" or so.
Doing a little research on teh intarwebs shows that some Porsches had wheel spacers from the factory. I've always believed/led to believe that spacers are bad evil things that should be avoided. But -- if they're good for Porsches from the factory????
I'm confused, hence, I'll ask a question of the collective -- any of you out there running spacers on cars that are driven in autox/HPDE events? We're not talking HUGE! spacers that would be needed, just something 1" or less. We're going for function, not hooptie-ness here
thx!
-jeff d
Austin (and Morris) Mini Cooper S's had spacers on the rear wheels, but they were built into the drums. Factory spacers.
