ignorant wrote:
I've readit 3 times and I don't understand what your saying? Diesel run at lower temps and produce ess heat than a gasoline engine due to the fact that diesel fuel contains less energy per gallon and the combustion process is more efficent so there is less heat available.
I'm sorry... but it just seems like you really don't know what your talking about. I'm not being confrontational or argumentative, but its the other way around... diesel has MORE energy per gallon than gasoline. The other thing is that higher combustion efficiency means there is MORE heat available. That's the whole point. In making more efficient combustion, you are releasing more of those stored BTUs as heat to be used for piston movement.
Gasoline has 124,000 BTU/gal whereas diesel is about 139,000 BTU/gal.
Sorry, but so far many of your arguments are based on faulty information. I respect you and your informative posts, and I'm not hacking on you... just letting you know that your basis for your discussion is potentially flawed due to the fact that your information on which you based it is incorrect.
245k so far on the wife's mercedes and all we've had to do is replace the radiator. 375k on my dad's Dmax that tows during the summer, but is a daily driver commuter for 5 miles back and forth to work. My LT1 couldn't make it 125k of daily driver status without burning oil, having piston slap, and compression issues.
