Since Miata is always the answer, will the stock wheels from a first gen Miata fit a 90 CR-X? Are they both lug centric or hub centric?
Sept. 19, 2010 4:19 p.m. porksboy Dork
Sept. 19, 2010 4:57 p.m. DeadSkunk Reader
Newer Hondas have a 56.1 mm hub diameter. I'm not sure about an older one like the CRX. Miata wheels are hubcentric, but only 54.1 mm in diameter. I don't think they'll fit.You should measure the CRX hub to see. Both are 4x100 bolt circle,I believe.
Sept. 19, 2010 5:50 p.m. mw HalfDork
The crx is 56.1. They won't fit
Sept. 19, 2010 5:58 p.m. Karl La Follette HalfDork
trhead pirate >will 280 zx rims fit first gen rx-7 235/60/14 s challenge car thanks karl
Sept. 19, 2010 6:14 p.m. Toyman01 SuperDork
In reply to Karl La Follette:
Nothing fits a 1st gen RX-7 unless it's a GSL-SE.
Sept. 19, 2010 6:30 p.m. Karl La Follette HalfDork
crap i was hoping to use the new skins on the 1st gen rx-7 off the parts z car i just got for the challange ,,,,,,,,,, back to the hunt for tires and rims
Sept. 20, 2010 6:54 a.m. bravenrace Dork
I've used them on a CRX. You just have to machine out the center (accurately) to fit.
