Fitzauto
Fitzauto HalfDork
7/26/15 11:23 p.m.
In reply to Kenny_McCormic:
Thinking Ill see if its okay but most likely going to bypass it.
Fitzauto
Fitzauto HalfDork
7/28/15 7:32 p.m.
Well cant find the berkeleying stop light switch. Where is it supposed to be?
Kenny_McCormic
Kenny_McCormic UltimaDork
7/28/15 7:52 p.m.
It's either a mechanical switch that the brake pedal lever hits, or a pressure switch on the distribution block/prop valve on the firewall or somewhere in the brake hydraulic circuits near the master cylinder.
Fitzauto
Fitzauto HalfDork
7/29/15 3:07 p.m.
Finally got the brake lights to work. Just jumped over the stop light checker. Any chance this will burn up wires or am I good to go?
Hungary Bill
Hungary Bill GRM+ Memberand SuperDork
7/29/15 4:05 p.m.
nah. Those bulbs and wires should all be safely rated for the system. It's not exactly a high amperage circuit, besides the fuse will ultimately protect the wiring from any dangerous failures. 10amp IIRC?
Glad you got it working!
Quick ninja edit: Just make sure your jumper wire is safely insulated and installed in a way that wont allow it to fall back out.
Kenny_McCormic
7/29/15 4:09 p.m.
No changes will be required bypassing that box. I recommend fully eliminating it from the taillight circuits.
Fitzauto
Fitzauto HalfDork
7/29/15 5:28 p.m.
Awesome. Thanks for all the help guys.
3f89cgKqKH3ENpTek87eXbxCLzuyM9MNhO4sYzBdLtwxUsXuJQbKr72HtvlyD8TL
