Login to post Forums » Grassroots Motorsports » WRX Strut Suggestion?
  • irish44j
    Aug. 21, 2010 9:33 a.m. irish44j HalfDork
    konis....
    /thread.
  • irish44j
    btw, there is a huge section on this topic on Nasioc, if you're looking for a "broad" consensus from WRX owners.
  • Per Schroeder
    Aug. 21, 2010 9:38 a.m. Per Schroeder Technical Editor/Advertising Director
    Konis really are the easy button. And you can adjust them if you want a little more trackworthiness in the future. There is also a Tokico option that's not bad---we're going to try a set of those on Tom's WRX.
  • Aug. 21, 2010 10:41 a.m. z31maniac Dork
    Koni/Bilstein is usually always a pretty good solution.
  • sachilles
    Aug. 21, 2010 11:39 a.m. sachilles HalfDork
    Koni's work fine, though I do have kyb gr2's on the back of my wrx wagon. Seem to work fine, lost one and they warrantied the replacement.
    I think the critical thing to do is the tophats, go with the group N mounts if you can swing it. Makes a world of difference regardless of the strut used.
  • Per Schroeder
    Aug. 21, 2010 5:51 p.m. Per Schroeder Technical Editor/Advertising Director
    There's a Whiteline front strut mount that adds some camber and is molded with the Group N rubber. That's what I'm going to use on the rallycross impreza. Gets me camber w/o using camber bolts that slip.
  • irish44j
    Aug. 21, 2010 10:53 p.m. irish44j HalfDork
    For those trying to look it up, it's known as the "Com-C" top hat, and in addition to adding some camber, it also adds some badly -needed caster.
    I am patiently waiting for it to come out for the new chassis (08+) wrx's so I can pair it with my new Bilsteins + 330lb springs :)
  • irish44j
    Aug. 21, 2010 10:54 p.m. irish44j HalfDork
    I don't think bilsteins are available for his car, FWIW. Could be wrong though...
  • Per Schroeder
    Aug. 22, 2010 6:17 p.m. Per Schroeder Technical Editor/Advertising Director
    You could go for the used STi struts, which were made by Bilstein?
  • irish44j
    Aug. 22, 2010 6:52 p.m. irish44j HalfDork
    AFAIK the only stock struts that Bilstein made for US-spec subarus were for the Legacty GT B-spec....but I could be wrong.
    Or you could buy an 08+ wrx and then get the new GTWORX/Bilsteins that are currently shipping!
  • Woody
    Aug. 22, 2010 7:05 p.m. Woody SuperDork
    Will STi struts bolt right up to a WRX?
  • Per Schroeder
    Aug. 22, 2010 7:15 p.m. Per Schroeder Technical Editor/Advertising Director
    The 04 ones will, IIRC>
