Got the hood open by cutting thru the hood. The hood release itself was stuck shut. The weird thing is it wasn't stuck when I went and looked at it.
Jan. 21, 2012 4:58 p.m. 93EXCivic SuperDork
Jan. 22, 2012 4:51 p.m. 93EXCivic SuperDork
So I was trying to use this to remove the glue left over from the headliner but it isn't working worth crap. Any one have any suggestions?
Jan. 22, 2012 8:57 p.m. SyntheticBlinkerFluid Dork
a mixture of automotive paint thinner and wax & grease remover.
We used to use it all the time to remove the adhesive from the lettering on box trucks when I worked at the collision repair shop.
Jan. 23, 2012 8:20 a.m. 93EXCivic SuperDork
Did you just mix it 50/50 and apply or apply them separately but at around the same time?
Jan. 23, 2012 9:13 a.m. Graefin10 Dork
3M Adhesive remover from NAPA
Jan. 23, 2012 9:18 a.m. 4cylndrfury SuperDork
best goo remover Ive found is good ol zippo fluid (mostly kerosene I think).
Jan. 23, 2012 10:12 a.m. kurtz New Reader
+1 Its naphtha.
Jan. 23, 2012 10:30 a.m. SyntheticBlinkerFluid Dork
I use a 50/50 mix, Sometimes 60/40 and apply it with a rag, then usually scrape it with a putty knife/gasket scraper. Sometimes apply it twice then scrape.
Good idea to buy a gallon of each.
Jan. 23, 2012 5:11 p.m. 93EXCivic SuperDork
Jan. 24, 2012 1:28 a.m. 4cylndrfury SuperDork
Oooohh fancy!
Jan. 30, 2012 4:01 p.m. 93EXCivic SuperDork
Jan. 30, 2012 5:37 p.m. Curmudgeon SuperDork
Did you get 4 of those Minilites, you lucky dog?
Jan. 30, 2012 5:50 p.m. 93EXCivic SuperDork
Yes thanks to GVX19.
Jan. 30, 2012 6:04 p.m. JThw8 SuperDork
93EXCivic wrote:
You keep collecting this Yugo stuff and I'll have to break out the rare collectibles to tempt you. How about a dealership Yugo parts and service sign? Its lit and functional ;)
Jan. 30, 2012 6:09 p.m. 93EXCivic SuperDork
JThw8 wrote:
Pictures? I am trying to find stuff to put in my garage.
Feb. 14, 2012 7:56 p.m. 93EXCivic SuperDork
Look at that massive engine!
Mostly gutted interior.
Feb. 15, 2012 5:30 p.m. 93EXCivic SuperDork
http://grassrootsmotorsports.com/forum/grm/what-paint-scheme/45601/page1/
So I am leaning towards an Alitalia paint scheme.
http://grassrootsmotorsports.com/forum/grm/kyb-spring-rates/45620/page1/
And trying to figure out the strut options. May involve an A1 VW front struts.
Feb. 15, 2012 9:35 p.m. SyntheticBlinkerFluid Dork
How did the glue removal go?
Feb. 15, 2012 10:04 p.m. 93EXCivic SuperDork
Haven't completely yet. I am going to try so other things tomorrow after I clean up the floor pans.
Feb. 16, 2012 8:34 p.m. 93EXCivic SuperDork
Ok so there is a small hole near the seam in sill. The metal around it seems fairly solid. Should I just Bondo that small hole and put POR-15 over it or weld it up?
Feb. 29, 2012 8:24 p.m. 93EXCivic SuperDork
That stuff is the E36 M3.
I have been doing body work and removing things like the heater.
March 15, 2012 8:08 p.m. 93EXCivic UltimaDork
The roof rack is deleted and the holes filled in. The side trim is removed and I have removed a decent amount of rust from the passengers side.
Does anyone know of a cheap source for fender mirrors?
Do you think it would look bad to have the interior of the car painted black and the outside a different color?
March 15, 2012 8:10 p.m. 93EXCivic UltimaDork
So the hatch is kinda E36 M3ty. I am pretty sure that I can't really repair it correctly. If I coat it with POR-15, will I be able to get this decently smooth with some work?
March 16, 2012 12:16 p.m. 93EXCivic UltimaDork
Anyone?
