Login to post Forums » Off-topic discussion » Dissolving Superglue
  • 93EXCivic
    June 28, 2011 4:32 p.m. 93EXCivic SuperDork
    So to make a long story short, the button on my clothes dryer is glued so that is doesn't move. How can I dissolve the glue and get it working? Will acetone work?
  • Capt Slow
    June 28, 2011 4:44 p.m. Capt Slow Dork
    I think acetone works with CA (superglue) but YMMV
  • ClemSparks
    June 28, 2011 4:58 p.m. ClemSparks SuperDork
    Fingernail polish remover will do in a pinch (like when someone sticks appendages together accidentally). I'm not sure what it is made of...now I'm thinking maybe it's acetone.
    If you have time to shop (as in, your ear is not glued to your shoulder, Ralph Wiggum style), go to a hobby store and find the solvent for CA (cyanoaccrylate...not sure on the spelling). It won't be cheap, but it'll work well.
    Clem
  • June 28, 2011 5:02 p.m. fasted58 HalfDork
    how did button get glued? jus wondering
  • 93EXCivic
    June 28, 2011 5:07 p.m. 93EXCivic SuperDork
    Something fell behind the dryer, I went to get it. Broke the knob. Tryed to put the knob back on...
    This is why I don't fix things in the house.
  • ransom
    June 28, 2011 5:28 p.m. ransom HalfDork
    When I worked at a hobby shop, one of the CA debonders we sold was straight nitromethane.
    Weird, but as true as my memory, FWIW. I don't recall whether it was more or less effective than the the other stuff (which looked/smelled quite different).
    EDIT: I had to doublecheck myself on the nitromethane thing after all these years, but if wikipedia is any more reliable than my memory (is it?), I have that correct, and acetone is indeed listed as well. Wikipedia on CA solvents.
  • madpanda
    June 28, 2011 5:39 p.m. madpanda New Reader
    I've used this one with good results: http://www.mcmaster.com/#super-glue-removers/=cy6blk
    It would suck to pay shipping for something that costs $2.40 though.
  • Duke
    June 28, 2011 6:55 p.m. Duke SuperDork
    Does the solvent need to be hootus-safe?
  • Toyman01
    June 28, 2011 7:00 p.m. Toyman01 SuperDork
    Acetone will work, but keep in mind that it will also dissolve a lot of plastics.
  • 93EXCivic
    June 28, 2011 9:14 p.m. 93EXCivic SuperDork
    Acetone no worky.
  • Toyman01
    June 28, 2011 10:08 p.m. Toyman01 SuperDork
    Must be new button time.
    Try these guys, I've had good luck with them.
    http://www.repairclinic.com/
  • mike
    June 28, 2011 11:59 p.m. mike Reader
    Most of the good CA dissolving fluids are nitroalkanes. A common product is nitropropane, for instance. If you have access, nitroethane may also work. Nitromethane is likely to be too volatile - though it sure eats paint!
  • 93EXCivic
    June 29, 2011 1:39 p.m. 93EXCivic SuperDork
    Thanks for the link I ended up using them.
  • KATYB
    June 29, 2011 1:55 p.m. KATYB Reader
    can u remove button to boil it?
  • June 29, 2011 2:04 p.m. spitfirebill SuperDork
    WD-40
  • GameboyRMH
    June 29, 2011 3:07 p.m. GameboyRMH SuperDork
    How much glue did you use? Can't you wiggle it free?
  • 93EXCivic
    June 29, 2011 3:11 p.m. 93EXCivic SuperDork
    Apparently a E36 M3 ton. Oops. Oh well I have a new switch on the way ($10 plus shipping).
