ProDarwin
ProDarwin UltimaDork
7/12/20 9:17 p.m.
Play by play of where I am now:
  • Go to make a sandwich and I grab a beer
  • Feels oddly not-cold
  • Take my cooking thermometer and stick it in the fridge for a min.  64 degrees
  • Pull fridge away from wall 7 unplug.
  • Take off rear panel and front intake panel.  This is a fridge with a bottom freezer and the coils are below the freezer.
  • Coils are absolutely caked with dust.  Obviously this is a problem.
  • Got a vacuum, paintbrush, and dragged my compressor & air nozzle upstairs to clean it out the best I can (its damn near impossible to reach the center of the coils).  Its not 100%, but probably 98% clean now.
  • Plug it back in.  I can hear a fan running inside the freezer, but nothing related to the compressor is running.
  • Unplug again.
  • Remove overload relay.  Shake it (internet recommended this) but it doesn't sound like anything inside it has failed.  Its not 100% solid, but it sounds like a loose-fitting metal contact does on other stuff - like european/us A/C adapters.
  • Put it back together and plug it in.
  • Still just have the freezer fan running, but no compressor kicking on.
  • The compressor feels warm to the touch but not hot.
What's my next step?
Stampie (FS)
Stampie (FS) GRM+ Memberand UltimaDork
7/12/20 9:36 p.m.
Drink warm beer.
slowbird
slowbird SuperDork
7/12/20 10:30 p.m.
we're dealing with a fridge problem too. freezer is cold but not freezing cold, fridge side is cool but not cold enough. it's over 10 years old so it's out of warranty. i dunno anything about fixing it so we either hope a repairman will call us back or we check for used ones on craigslist.
it sucks.
jgrewe
jgrewe Reader
7/12/20 10:36 p.m.
Does it have a timer for the defrost?  If it does find it and you should be able to turn it manually to see if it is stuck in the defrost period.
ProDarwin
7/12/20 10:50 p.m.
I can't find any settings for defrost, but that cycle should only last a like 30 mins though.  It's been plugged in again for an hour or so.
jgrewe
jgrewe Reader
7/13/20 12:30 a.m.
Yes, but the timers stop working and get stuck in defrost or chill.
ProDarwin
7/13/20 9:09 a.m.
Evaporator was frozen solid.  Appliance guy cleared most of it out with a heat gun, but there is a nice solid block around the heater inlet for the defrost and I have to let it thaw another 24 hours or so before I can plug it in.
I have saved some meat and cheese, but pretty much everything else is going in the trash :/  On the plus side, its a good time give the inside a deep clean.
The main issue is likely the intake of warm air from a door not sealing properly.  The RH door has material bubbled up on the top where it should be flat (manufacturing defect or something) but I didn't catch it under warranty.  If the door is left to close under its own weight it will often get stuck.  I might have to see if I can tweak this area with a heat gun or something.  A new door is $7XX surprise
BlindPirate
BlindPirate Reader
7/13/20 7:59 p.m.
Is your refrigerator running? Better catch it before it gets away!
66WCjomIgtEXYIno5a3m2zh9m4jqQZPeeJb1G60pk1SBKSqiFbmnK9FkBQQQpWdl
