I've got a bit of a strange application.
When my mother moved into her home 2 years ago, we recognized she needed a wheelchair lift. Wheechair lifts are expensive, so in typical grassroots fashion I came up with an alternative.
We found an ebay bargain on a wheelchair lift designed for a bus. It was well made, and it's hydraulics were pretty simple, but the electrical was convoluted. It was designed to run off dual controls at both the top and bottom, with an over-ride at the driver's seat. We got all the controls, etc.
It also ran on 24V.
I modified the harness to work, and did a lot of searching for an converter that would convert the 120 AC household current to 24V DC. That turned out to be a rare animal.
So, the alternative I chose was to install 2 deep cycle automotive batteries in series. Worked great.
The batteries would last about a week before needing a re-charge. Ultimately, I found 2 small 2A 12V trickle chargers and hooked one to each battery (with the batteries still connected to each other). I don't know why this seemed to work- my logic was saying that 12 volts tied to 2 different sides of a 24 volt system was not going to work, but it did work fine for 2 years.
But this week both of the chargers died. The batteries are fine.
So, my question is, was this just a screwy setup that was doomed to fail and I got what I deserved, or is it just a coincidence that they both died together? Should I just go buy 2 new chargers, or do I need to make an effort to find the 24V charger or converter? Why did it work in the first place?
Just looking for a bit of an education.
