Okay GRMers, my local independent Honda guy is on vacation, and I need a hand figuring out what is wrong with the wife's civic before i give up and take it in to the dealer.
Recently, I had to replace the battery was replaced for a no-start. Since then, we've taken a long trip in the car, and I've noticed that the headlights / interior lights "pulse" while the engine is running. It does not seem to change with by engine speed, and the voltage is steady on my digital multimeter.
I suspected a bad voltage regulator, and opted to replace the alternator (regulator is internal) with one from the parts store. That did not resolve the issue. The car also has a new belt, and I replaced the positive terminal on the battery due to corrosion. Grounds and other connectors are all nice and clean/shiny/tight.
The car has one of the Honda ELD gizmos in the fuse box. I pulled the plug off and it's got battery voltage and 5v from the ECU like it's supposed to. Unplugging the ELD gizmo does not seem to change anything. I probably need to backprobe this thing and see if the voltage varies with electrical load like it's supposed to.
Checking the voltage at the battery with the car running, I get 14.4-14.8v depending on if i've been driving or not. If i unplug the 4 pin connector from the alternator, i believe it stops charging completely, as the voltage measured at the battery drops to 12.1-12.0 and the headlights dim a bit and stop pulsing.
Any input would be appreciated. Thanks!
