Just picked up a pair of relatively minty front-corner indicator housings for my Samurai.
These are made entirely of rubber and normally turn into a black goo with a crumbly outer crust and fall apart at around 15 years old. Any tips on how I might prevent this from happening? Maybe slather some RTV onto the back to reinforce it and seal away the stock rubber from one side?
Edit: Think I should put aluminum tape on the bulb side to make a better reflector?
Did the aluminum tape mod:
This should help to boost the normally dim glow of the lights.
Seems like ozone an UV rays are the two things that damage rubber...though I could be wrong. But I suppose your goal would be how to protect the housing from those two things. Plasti-dip maybe?
Make a silicone mold of each then just make new ones out of fiber reinforced silicone?
I'd be hard pressed myself to not replace them with led markers on a sammi.
I was just thinking about something like that this morning...good idea.
You mean these?
http://www.trail-gear.com/led-lights
Maybe if they're a direct fit. But one of those is almost as much as I paid for two of these, and that's before shipping and duty.
I guess I wouldn't be too worried about direct fit on a Sammy. I'd be torn between a small chunk of aluminum with a 3/4" hole in it for the small round lights dell city sells and using a 2" panel punch or hole saw to make a perfectly round hole for a grometted 2" semi trailer light, also available from del city.
http://m.delcity.net/store/LED-Mini-Marker-Lights/p_797830
http://m.delcity.net/store/LED-Side-Marker-Lights/p_797820
I usually clean them first w/ citrus solvent and a nylon brush, then soak 'em in Armor All.
That was my fallback option, guess that's what I'll do.
