So a few days ago the Samurai refused to start. After checking the ignition coil, I found that the resistance across the primary coil is off by a factor of 4 or so (mind you the multimeter doesn't do fractions :( I'm getting a new one). The primary coil resistance was also far off on one I bought, which appears to have been returned, and on a used one I got to try out. When checking the ignition system I found some badly worn parts, so the distributor cap, rotor and cap seal were replaced right off the bat. Later when testing the replacement ignition coil, I found that no spark would jump from the distributor to the plug wire but when I cranked it the tach would move - in a very odd erratic way, but it was moving. I only have 1 day to fix this problem so if there's anything else that could be broken I need to replace it. Should I just get the ignition coil exchanged or could something else be causing this? The only thing I could imagine is the wire from the ignition coil to the distributor being broken, but it was running fine just a few hours before it broke down (although with very rough starts) and if it was broken I guess the spark would still jump the gap and wouldn't prevent the car from even sputtering when cranked.
Any ideas?
