Login to post Forums » Off-topic discussion » Oops! Ford QC slips up on a Boss 302
  • Javelin
    April 26, 2011 11:35 a.m. Javelin SuperDork
    Motor Trend article
    Apparently one of the Boss 302 testers had a brake clevis pin snap, and the pedal itself was incorrectly installed, resulting in zero brakes. Luckily all Boss 302's have actual manuals (hooray for Ford!) and the driver was able to go down through the gears and save the car.
    The only thought is that maybe the master cylinder had been pulled and replaced, and whatever monkey that hooked the brake pedal back up did it wrong. Except nobody has any proof that the MC ever came out of the car, so it could have equally been a production-line error.
    Bravo to Ford for shutting down the Mustang line and trying to figure out the issue though.
  • mad_machine
    April 26, 2011 11:37 a.m. mad_machine SuperDork
    how do you snap a clevis pin? Those things are usually pretty stout and with lots of support
  • Javelin
    April 26, 2011 11:43 a.m. Javelin SuperDork
    Probably because it was installed incorrectly. The article says that the brake rod is a u shape and the pedal goes in the middle, so if a broken clevis does happen, the pedal catches inside the u and still operates the master cylinder. This one was installed to the outside of one of the u's, so it likely put a ton of shearing force on that clevis. The car was tracked around Laguna Seca like that!
  • Giant Purple Snorklewacker
    April 26, 2011 11:53 a.m. Giant Purple Snorklewacker SuperDork
    Giant Purple Snorklewacker wrote: That pin looks like plastic over a thin screw.
    The pin on my E30 is a solid 12mm rod like 99% of every pin/clevis combo I've ever seen used. The one in my Chevelle is 1/2" rod - I'm not sure why anyone needed to change the basics - probably to address some customer complaint about a squeaky pedal.
  • tuna55
    April 26, 2011 11:54 a.m. tuna55 SuperDork
    As a former OEM supplier who has sen one extremely, :: interesting :: event occur during a press day, I can wager a guess that this was tampered with after the factory was through with it. I don't mean sabotage, I mean idiocy.
  • mad_machine
    April 26, 2011 2:37 p.m. mad_machine SuperDork
    well.. idiocy knows no bounds. We even see it here on occasion.
  • FlightService
    April 26, 2011 2:39 p.m. FlightService HalfDork
    Outside the U it is cantilever arrangement.
    Ford needs to Poke Yoke that thing!!!
  • tuna55
    April 26, 2011 2:56 p.m. tuna55 SuperDork
    I'll just say that you'd assume that air would fill tires. Nitrogen even...
    Things people do boggle the mind. It wouldn't surprise me one bit if some local shop was hired to do a tune up or some such thing and put together the clevis wrong.
  • CarKid1989
    April 26, 2011 4:21 p.m. CarKid1989 Dork
    details?
  • njansenv
    April 27, 2011 7:56 a.m. njansenv HalfDork
    ^ I wouldn't be so sure. $0.12 or otherwise, it's a "SRC" (safety related component) and there would normally be all sorts of extra QC steps associated with that.
  • Kendall_Jones
    April 27, 2011 8:47 a.m. Kendall_Jones Reader
    Did they add a data logger to this car? Maybe someone hooked up a brake POT & reassembled it worng. Also, I can totally see that as a blind job, reach under dash & feel the plunger / hole (heh heh).....
    KJ
  • tuna55
    April 27, 2011 9:56 a.m. tuna55 SuperDork
    KJ
    That's pretty likely - although "they" could have been anyone between the factory and MT.
  • WilberM3
    April 27, 2011 10:18 a.m. WilberM3 HalfDork
    serously, where's the metal? it looks like its not only smaller, but only the middle part actually sheared. i can understand covering a normal pin with something to quiet it down, but that looks looks like they replaced it.
