Login to post Forums » Off-topic discussion » Pressure Washing Brick and Concrete
  • jrw1621
    Aug. 13, 2011 6:35 p.m. jrw1621 SuperDork
    We moved to a new house last month. Many projects to be done. Today I got around to the pressure wash project. The house is 100% brick exterior and white brick at that (not painted but rather white brick.) Due to shaddy areas some of the brick has gotten a bit mossy and/or black in spots. Weeks ago I borrowed a friends Black and Decker little, residential electric power washer. It sucked and did not do well.
    I made a reservation and for $50 for the whole weekend, picked up a commercial rental 3000 psi washer with a 9hp honda engine this morning. While there I told the guys at the shop of my project for some brick and some concrete. You see, there is sort of a courtyard in the front walk and again, due to shade, the concrete has a lot of dark coloration here at this house of 38 years old. While talking about concrete the shop guy says, "you need the concrete attachment - I'll throw it in for the same price." Not sure what this is I said, okay.
    This is what came with it.
    Video: http://www.mitm.com/support/videos/
    I did not know shuch a thing existed (and that is why I am sharing this here.) Sort of like a floor buffer. Under the hood is a rotating pair of jets. When you squeeze the trigger the whole thing floats a little on exiting water.
    Well, the brick task worked as expected with just the hand wand but when I turned this concrete brush on that is where the amasement happened. My front courtyard walk came out beautiful. The issue came from where to stop???
    My house was a custom build in 1973 and is pretty unique. A shared private concrete drive goes back about 250' from the main road and then splits off to my house. Then the concrete widens at the front of my house. I have 35' x 80' of concrete out front or about 2,800 sq ft. In about 8 hrs I covered the entire area with this power washer / floor buffer-ish thing.
    All of my concrete is so clean it is almost so white that it is actually hard to look at in direct sunlight. It is the kind of thing that you only do once ever 38 years but boy does it look nice.
    All in all, I just wanted to share that this type of thing exisit. I did not have oil spots so I can not comment on how it would work there but my guess is very well.
  • donalson
    Aug. 13, 2011 7:10 p.m. donalson SuperDork
    yup those things are pretty nice... they also have versions for tile (have the vacuum port from the carpet "steam" cleaner... they have much larger ones also that instead of having to push around on brushes they have casters... if you've got a wood deck try it out on that also... :)
  • foxtrapper
    Aug. 13, 2011 7:19 p.m. foxtrapper SuperDork
    I never knew of such an attachment either. Glad to now know!
  • DrBoost
    Aug. 13, 2011 7:51 p.m. DrBoost SuperDork
    I wonder if that would work with my Home Depot Pressure washer. I think it has a 5HP Honda.
  • Hal
    Aug. 13, 2011 8:18 p.m. Hal Dork
    Northern Tool has a bunch of different sizes and configurations of them.
    Northern Tool Surface Cleaners
  • Aug. 14, 2011 8:22 p.m. dj06482 HalfDork
    Thanks, I have to powerwash our brick walk this year and this attachment looks like a must-have!
  • alex
    Aug. 14, 2011 11:57 p.m. alex SuperDork
    Oh man. I have a big brick patio that needs a pressure wash basically once a year. This looks like it will significantly improve my life.
