Login to post Forums » Off-topic discussion » Rear view mirror windshield glue recommendation?
  • BoxheadTim
    April 12, 2011 1:41 p.m. BoxheadTim SuperDork
    The mirror on my wife's Cherokee has fallen off, so I either need to take it to an auto glass place to get the mirror reglued or do it myself.
    Anybody got a recommendation for the 'proper' glue to do this or should I just go see the local glass place?
  • Ranger50
    April 12, 2011 1:47 p.m. Ranger50 HalfDork
    The most expensive/extreme version from the parts store. The cheaper/weaker versions never hold for me even doing the same level of prep for both.
  • tuna55
    April 12, 2011 2:07 p.m. tuna55 Dork
    This exactly. When done correctly there will be no issue. Use a razor to clean, then a good alcohol that doesn't leave a residue. Don't overdo it or you'll have a glue drip on your windshield forever.
  • Duke
    April 12, 2011 2:18 p.m. Duke SuperDork
    I did my GC using the most expensive stuff at NAPA. It worked great and is still there.
  • Derick Freese
    April 12, 2011 2:22 p.m. Derick Freese Dork
    So, is this a problem with XJs? For serious, the rearview in my XJ keeps falling off. Maybe I need to pony up for some of the expensive stuff.
  • madmallard
    April 12, 2011 3:00 p.m. madmallard Reader
    i got tired of "glue" never setting.
    I used 2-part epoxy after the 3rd time it fell. never fell again.
  • 914Driver
    April 13, 2011 6:00 a.m. 914Driver SuperDork
    I had to relocate the hook on the 914. NAPA seels the stuff, works great. DO NOT attempt to remove the old one, it'll break the windshield.
    Dan
  • Wally
    April 13, 2011 6:05 a.m. Wally SuperDork
    Also make sure you don't put the tab on backwards.
  • Jay
    April 13, 2011 6:34 a.m. Jay SuperDork
    I bought a Permatex "Rearview Mirror Adhesive Kit" when the mirror fell off my Elan when I'd first gotten it. Three years later dealing with the kind of weather protection only a British roadster can offer, and the kind of horrible cobblestone streets only small-town Germany can offer, and it's still stuck on fast. The kit came with a scraping razor and the right kinds of scouring/cleaning pads too. Here it is for six bucks.
  • BoxheadTim
    April 13, 2011 8:51 a.m. BoxheadTim SuperDork
    I hesitate to ask how you would know...
    NAPA lists this kit too, that's the one I'll try to get on the weekend then.
  • Wally
    April 13, 2011 9:23 a.m. Wally SuperDork
    One side should have two little tabs hanging off the long sides that fit inside the mirror, don't glue that side to the glass.
  • JFX001
    April 13, 2011 10:00 a.m. JFX001 SuperDork
    I used a grease pencil on the outside to trace the outline of the tab.
  • DoctorBlade
    April 13, 2011 10:17 a.m. DoctorBlade HalfDork
    I used the kit we had in the shop when one fell off the delivery truck I was using. I think it was that permatex kit. Good Prep is key.
  • Duke
    April 13, 2011 11:11 a.m. Duke SuperDork
    Cigarette lighter or one of those long butane match things on the outside to the glass. Heat it for 45-60 seconds and pop the shoe off the inside with a pair of slipjoint pliers. Job done.
  • tuna55
    April 13, 2011 11:28 a.m. tuna55 Dork
    why? just put the glue on the tab.
  • keethrax
    April 13, 2011 12:25 p.m. keethrax Reader
    It's not to limit where the glue goes, it's to make sure the tab goes in the same spot. At least that's why I did it.
  • tuna55
    April 13, 2011 12:50 p.m. tuna55 Dork
    But you have a double ball jointed stick attached to the mirror, you could be off by five inches and still get the mirror in the right place.
  • Duke
    April 13, 2011 12:51 p.m. Duke SuperDork
    Yes, but if you get it back in the right place, it looks like you might actually know what you're doing.
  • keethrax
    April 13, 2011 1:21 p.m. keethrax Reader
    Getting it in the right spot adds essentially zero cost and less than a minute to the process. Why wouldn't you get it right if it was that easy? Even if the range of adjustment can cover for you.
  • JFX001
    April 13, 2011 1:22 p.m. JFX001 SuperDork
    Yes, I just outlined the tab residue on the outside of the windshield, because when you prep the inside it disappears.Just for a reference point.
  • Tom Suddard
    April 13, 2011 1:38 p.m. Tom Suddard SonDork
    You must be the PO that wired the stereo that came in my E30, and designed the throttle linkage (I'm using that term loosely) that had been "installed" on the Spitfire.
  • tuna55
    April 13, 2011 1:41 p.m. tuna55 Dork
    hey now - come on. Sticking a mirror thingie on in the right place hardly has any practical effect, even if it was measurably off, which I doubt any of them I have done were.
  • tuna55
    April 13, 2011 2:21 p.m. tuna55 Dork
    Plus, I am pretty sure that every time I had put one on it was because THERE WAS NOT A MIRROR THERE - otherwise why would I glue a new one on?
