Login to post Forums » Off-topic discussion » Router upgrade - tips and tricks?
  • jstein77
    Nov. 16, 2011 8:25 p.m. jstein77 Dork
    I'm upgrading from a Netgear Wireless-G (WGR614) to a Wireless-N (N150) router. Could this be as simple as plug-and-play, or do I need to uninstall the old software and start from scratch?
  • turboswede
    Nov. 16, 2011 8:34 p.m. turboswede SuperDork
    Don't need the software. Just log onto the old router via the web address and print out the configuration.
    Then plug in the new router, connect it to your machine, log onto the internal web address and plug in the configuration settings.
  • Derick Freese
    Nov. 16, 2011 8:46 p.m. Derick Freese Dork
    Who do you use for your ISP? That's going to determine how that router gets set up. If you're in the North East and have Verizon, you're going to set the internet connection type to PPPoE and use your Verizon username and password as the username and password. If you're on cable, you'll likely be DHCP, so it will either be set up as DHCP or "obtain automatically". Some DSL providers in some areas use DHCP, but a lot of them are PPPoE. Find out by logging into your old router at 192.168.1.1 (most likely) and see what it's set up as.
    This stuff is my day job and my side job. If you run into trouble, make another post back here and we can go over it on the phone.
  • jstein77
    Nov. 16, 2011 9:15 p.m. jstein77 Dork
    I'm on a Bright House cable modem in central Florida.
  • Derick Freese
    Nov. 17, 2011 10:09 a.m. Derick Freese Dork
    disconnect the old router, power down your modem, connect new router but leave it powered down, power up the modem, wait 1 minute then power up the router. that should get you connected.
