Login to post Forums » Off-topic discussion » Ubuntu install problem
  • May 13, 2010 6:45 p.m. petegossett SuperDork
    I've googled & didn't find anything...
    You guys have made me an Ubuntu convert, I've been running it on a crappy Dell for several weeks, and the install was painless.
    I decided to load it on a home PC that has a corrupt/illegal copy of XP Pro, and completely get rid of XP.
    When I get to the Ubuntu screen to select a partition, there is nothing there to choose from & I can't go any further.
    How do I get past this?
  • rmarkc
    May 13, 2010 7:08 p.m. rmarkc Reader
    Is it a SATA hard drive? Maybe check BIOS and see if it has an IDE mode for the SATA controller.
    But I have an all SATA setup and didn't have that problem installing Ultimate Ubuntu 2.3, 2.4 or 2.5.
  • May 13, 2010 7:20 p.m. petegossett SuperDork
    Yes, it's SATA formatted with NTFS.
  • May 13, 2010 7:54 p.m. petegossett SuperDork
    Ok, this is odd...
    From the Ubuntu installer I did ctrl/alt/f1 to get to the command line & ran "sudo lshw -C disk" but it didn't find the HDD, just the DVD drive???
    That's odd since XP is still booting.
  • May 13, 2010 8:03 p.m. petegossett SuperDork
    Hmm...this may have something to do with it - just checked bios & see the HDD is listed as "third IDE master".
    Not sure what's up with that?
  • rmarkc
    May 13, 2010 8:29 p.m. rmarkc Reader
    That is odd. Maybe open the PC and move the HD connector to another SATA port on the motherboard.
    If you only have the one HD and a DVD, I would put the HD on SATA port 0 and the DVD on port 1.
    If you are using a live CD for the install, you should be able to open System->Administration->Partition Manager to see if the drive is present instead of going all the way through the install.
  • May 13, 2010 8:41 p.m. petegossett SuperDork
    Thanks!
    I opened the terminal from the live CD & tried "sudo apt-get -y remove dmraid" which was one suggestion I found online, but when I open up GParted it still doesn't see the HDD. Oh yeah, I did try moving the SATA cable around too.
  • rmarkc
    May 13, 2010 8:59 p.m. rmarkc Reader
    Does the MB support RAID? Have you tried disabling it in BIOS?
    I've installed Ubuntu on a wide mix of hardware and never had a problem with it not seeing a hard drive.
    If you have the time (and bandwidth), download Ultimate Ubuntu and give it a try. It is a heavy distro and you will need to burn it to a DVDR.
    Another approach would be to make an install on USB, disconnect the DVD drive and boot from the USB.
  • GameboyRMH
    May 14, 2010 10:05 a.m. GameboyRMH SuperDork
    Wow, never seen that before. What do you get if you run sudo fdisk -l from the boot CD?
  • May 14, 2010 11:05 a.m. petegossett SuperDork
    Nothing, it doesn't see any drives.
    I didn't find any settings in bios for raid. I built this PC about 5-years ago, but I'm not sure if I still have the documentation for the MB around.
    I did find some online links referencing similar problems with WD hard-drives(which I have), so I'm going to grab a small/old IDE drive & cable and see if it will recognize it.
    What's weird is when I move the SATA cable to each of the 4-ports in bios it only shows up as 3rd-master, 3rd-slave, 4th-master or 4th-slave. I'm not sure how to change it to 1st-master, I'm guessing jumpers, but I'll need to either find the manual or google it & see if anything comes up.
  • GameboyRMH
    May 14, 2010 1:45 p.m. GameboyRMH SuperDork
    Yeah check your BIOS manual, there was a trick to it with some older mobos but I'm not remembering it now.
    If you see nothing at all from fdisk, it's not a software / filesystem level problem. I wonder how you got it installed in the first place actually
    Edit: Do I understand correctly that you installed it and now can't boot to Ubuntu, or are you saying you've never been able to choose a partition in the installation wizard?
  • rmarkc
    May 14, 2010 6:24 p.m. rmarkc Reader
    Most MB manufacturers have PDFs of the MB manuals available on their website if you can find the manf. and model #.
    The manual will tell you what the chipsets are, and once you find that, finding a solution should be much easier.
    Does the MB have 2 IDE connectors? That could explain the 3rd and 4th master and slave stuff, 1st and 2nd are reserved for IDE.
    Is the DVD IDE? With the master/slave wierdness, having a DVD drive on an IDE connector could be masking the SATA HD. If you have access to a USB DVD, you could try disconnecting the internal and boot from USB. That might make the HD visible to linux.
  • May 14, 2010 10:25 p.m. petegossett SuperDork
    In reply to GameboyRMH:
    I've never been able to install Ubuntu, just running it off the disk. It never finds any partitions.
  • May 15, 2010 2:02 p.m. petegossett SuperDork
    Small update/success - I dug up an old 8.4gig HDD and IDE cable and bios recognized it as primary master, and still saw the SATA drive too.
    So I tried installing Ubuntu again, it found the 8.4gig drive fine & I'm doing the install now. It still didn't see the SATA drive, so I doubt it will find it after the install is done, but at least it's up & running!
    Thanks for all the suggesions & help!
