Login to post Forums » Off-topic discussion » Welding at Apartment
  • PHeller
    July 14, 2011 9:29 a.m. PHeller Dork
    I could have sworn I already made a post asking about this:
    My apartment has no power to the garage, so I run an extension cord out there.
    When funding permits, I'd like to get a small welder to make repairs on my trailer, motorcycle, etc.
    Can I do this with a normal 110 outlet/extension cord?
  • DILYSI Dave
    July 14, 2011 9:44 a.m. DILYSI Dave SuperDork
    For a 110 welder, yes (get the heavy gauge extension cord). If you want a 220 welder, you'll need to run the extension cord to the dryer plug.
  • PHeller
    July 14, 2011 9:46 a.m. PHeller Dork
    What the max penetration of a 110 welder?
    I'm thinking of welding frames, 1/8" plate or something like that would be maximum that I'd work with.
  • Duke
    July 14, 2011 9:59 a.m. Duke SuperDork
    This thread is relevant to my interests.
  • cwh
    July 14, 2011 10:01 a.m. cwh SuperDork
    A decent 110 welder will handle that. Hobart, Lincoln, Miller, no problems. They are rated at 130 amps. Just invest in a big, heavy gauge cord.
  • Curmudgeon
    July 14, 2011 10:02 a.m. Curmudgeon SuperDork
    You shouldn't have any problem welding light duty stuff with a 110v unit, particularly if you keep the duty cycle below 50%. Like Dave says, get the biggest gauge extension cord you can because voltage drop is not your friend.
  • Giant Purple Snorklewacker
    July 14, 2011 10:52 a.m. Giant Purple Snorklewacker SuperDork
    I can get really nice penetration on 3/16" in a single pass with my Miller 140 and .030 wire - I have done 1/4" but it it right at the limit of having to do 2 passes.
    It thrives on 1/8", .120 and .095 wall roll cage tubing though.
  • PHeller
    July 14, 2011 10:58 a.m. PHeller Dork
    I'm just thinking of welding little brackets and making trailer repairs, not an oil tanker.
    What kind of average fix in your garage kind of stuff is thicker than 1/4"?
    Can you weld an exhaust with a 110 MIG?
    July 14, 2011 11:19 a.m. Giant Purple Snorklewacker SuperDork
    I did that with a 110v welder. Brakes are still on the car after 60 track days.
    I also built the entire exhaust from mandrel bent tubing with the same welder.
  • GrantMLS
    July 14, 2011 12:55 p.m. GrantMLS Reader
    Thought this was going to be how do I weld in my apartment and still get my deposit back kind of thread..
  • slantvaliant
    July 14, 2011 1:00 p.m. slantvaliant Dork
    When you're getting that heavy-gauge cord, only get it as long as you need to reach where you can reasonably weld. In this situation, shorter is better.
  • 1988RedT2
    July 14, 2011 1:25 p.m. 1988RedT2 Dork
    Surely you don't mean "Long and thin will get it in, but short and fat is where it's at?"
  • ultraclyde
    July 14, 2011 1:43 p.m. ultraclyde HalfDork
    I run my Lincoln 125 110v MIG on short fat extension cord in my shop all the time. and I make brackets, fix lawnmowers and generally stick any steel I have any business messing with. If it needs steel that's to thick for my welder, I'm probably not qualified to weld it anyway! I actually ran a 2 plug box on the end where I plug it in so that I don't have to keep unplugging it to plug in my grinder. Works great.
  • mad_machine
    July 14, 2011 4:23 p.m. mad_machine SuperDork
    this brings up a good point. I CAN'T weld at my garage due to power constrants. (power is shared with other tenets.. if I am alone, no problem...) Has anybody ever used a generator to run a welder?
  • Toyman01
    July 14, 2011 4:35 p.m. Toyman01 SuperDork
    In reply to mad_machine:
    Yes, but it need to be a fairly large one depending on what you are welding. My 10kw diesel generator is good to about 130 welding amps on a 220V machine. Anything over that and it starts rolling the black smoke and looses frequency or trips the circuit breaker.
  • DaveEstey
    July 14, 2011 4:49 p.m. DaveEstey HalfDork
    I've seen it done at the track but haven't done it myself.
  • Marty!
    July 14, 2011 7:57 p.m. Marty! Dork
    Most 110v will weld up to 3/16 so exhaust will be no problem. I use a pretty thick 50 foot cord to run mine all the time.
    My only .02 is if you are shopping for a welder to meet your needs, skip the flux cored and go straight to a bottle set up. You will save yourself a lot of headache later on.
    Also unless you plan on doing custom suspension or frame work you won't really see too much need to have a welder that does anything larger than 3/16 anyway.
  • 1988RedT2
    July 14, 2011 8:08 p.m. 1988RedT2 Dork
    My brother visits me a couple times a year, and he usually brings his welder to help me with the Chevy II. On one such visit a year or two ago, the power went out as we were prepping to weld. Not to be discouraged, I dragged out my Coleman generator. I think it's like 6500 watts, and has a 230-volt outlet. My brother's MIG is a 230-volt Hobart. He wanted to try it to see how it did. It was fine.
    So yes, you can use a generator to run a welder, so long as it's sized properly.
  • knb13
    July 14, 2011 8:27 p.m. knb13 New Reader
    haha
    Look into getting a gas mig- the gas helps to shield the arc and provides cleaner welds.
    Or get a welder than you can always add that onto later when funds allow.
  • Curmudgeon
    July 14, 2011 8:49 p.m. Curmudgeon SuperDork
    I have built 5/16" thick brackets, repaired broken 3/8" plate (beveled and ran multiple passes on both sides), welded countless pieces of 1/4" and 1/8" whatever and built several .095 and .134 wall cages, all using a 110v Lincoln with flux core wire running on a 20 amp circuit breaker. But for some reason everyone tells me it sucks and couldn't possibly work? Dayumn. I must be doing something wrong.
  • Toyman01
    July 14, 2011 9:25 p.m. Toyman01 SuperDork
    In reply to Curmudgeon:
    You are. Get over it.
  • BoostedBrandon
    July 14, 2011 10:36 p.m. BoostedBrandon Reader
    The only thing about a MIG is that any sort of breeze can affect the cloud of gas and screw with your weld. You can weld outside with a mig, but they're much more sensitive to weather.
  • friedgreencorrado
    July 14, 2011 11:46 p.m. friedgreencorrado SuperDork
    This. I don't know anything about welding, but I know enough about houses to say that most of them have a 220 outlet in the "laundry room". Buy an extension cord with enough insulation to take the heat.
  • Wally
    July 15, 2011 1:54 a.m. Wally SuperDork
    Weld on the stove top and run the exhaust fan. Sparks don't hurt the finish on the stove, and the fan sucks out the fumes.
  • bluej
    July 15, 2011 5:47 a.m. bluej Dork
    Got a light in the garage?
    http://www.amazon.com/gp/aw/d/B001ATG0JU/ref=redir_mdp_mobile/175-1751698-6959534
