Login to post Forums » Off-topic discussion » What gauge steel and size tubing for locust frame?
  • joey48442
    June 18, 2011 7:28 p.m. joey48442 SuperDork
    What size do you guys think?
    Joey
  • 93EXCivic
    June 18, 2011 7:43 p.m. 93EXCivic SuperDork
    Square 1"x1" will be easier to work with than round IMHO.
  • joey48442
    June 18, 2011 7:45 p.m. joey48442 SuperDork
    Cool. What gauge?
    Joey
  • John Brown
    June 18, 2011 7:54 p.m. John Brown SuperDork
    It would greatly depend on what power and load projections you have.
    I will assume you will be using a Miata drivetrain, I will suggest this site for a quick read on the subject.
  • JoeyM
    June 18, 2011 8:01 p.m. JoeyM SuperDork
    Locost USA is, indeed, a good site.
    What you want are the McSorely Plans. I think they call for 16 gauge square tubing. I'm using 14....stronger and easier to weld because it is thicker/heavier. 16 gauge is 0.827 lbs./ ft. 14 gauge is 1.04 lbs/ft. That's an extra 42 lbs for 200' of tubing.
    In a given gauge, round tube will be stronger/lighter than square, but most people stick to square because round is more of a pain in the butt to fit up. (You need to fishmouth every joint in round tubing instead of just cutting the tube at the correct angle like you do with the square stuff.)
  • nocones
    June 18, 2011 8:16 p.m. nocones HalfDork
    I used 14 gauge (.083) for my midget until the "main" structure was done then switched to 16 ga (.065). The 14 definately welds easier but it is heavier..
  • SkinnyG
    June 18, 2011 10:38 p.m. SkinnyG HalfDork
    Lethal Locost #2 is being made mostly out of 18ga tubing, with a lot more round than #1 had.
  • 93EXCivic
    June 18, 2011 11:12 p.m. 93EXCivic SuperDork
    joey48442 wrote:
    Cool. What gauge?
    Joey
    We are using some .065" wall (16 gauge) for parts of the Formula frame. It does depend on the loads you are planning on putting on the car.
  • fritzsch
    June 18, 2011 11:31 p.m. fritzsch New Reader
    .065'' should be fine for the frame, I would also go with round for most of it
  • June 18, 2011 11:31 p.m. fasted58 HalfDork
    .030" W tubing and drill the centers out of all the bolts
  • DeadSkunk
    June 19, 2011 9:33 a.m. DeadSkunk HalfDork
    Joel,are you thinking of building a locost with your stash of Miata bits?
  • joey48442
    June 19, 2011 5:25 p.m. joey48442 SuperDork
    Yessir!
    Joey
  • JoeyM
    June 19, 2011 7:09 p.m. JoeyM SuperDork
    joey48442 wrote:
    Yessir!
    Joey
    I just noticed the thread title spelled it 'locust' even though it is 'locost'.....now I know why some people don't say "low cost"; they're repeating the way they have seen it spelled.
  • SkinnyG
    June 19, 2011 10:04 p.m. SkinnyG HalfDork
    "Locust" was a Sevenesque kit out of the UK that was aluminum sheathed plywood on a tube steel frame.
  • joey48442
    June 19, 2011 11:09 p.m. joey48442 SuperDork
    JoeyM wrote:
    joey48442 wrote:
    Yessir!
    Joey
    Oh, that was just the dumb spell check on the iPhone. I meant locost.
    Joey
  • JoeyM
    June 20, 2011 11:48 a.m. JoeyM SuperDork
    No big deal, it just reminded me of the comments in that other thread
