EdenPrime
EdenPrime Reader
6/30/13 9:17 p.m.
Hi, i'm sorry for such a basic question, but does anyone know if Stainless Steel Brake Lines for a 2001 Accent would fit a 2007 Hyundai Accent? Do they use the same connectors?
clownkiller
clownkiller Reader
6/30/13 9:31 p.m.
1995-2005 have the same part number 2006-2007 have a different part number, Rock Auto.... That being said I ran 92 Civic lines on a 85 CRX.
EdenPrime
EdenPrime Reader
6/30/13 9:37 p.m.
In reply to clownkiller:
I thank you for your reply, but i don't feel as though i've gotten an answer. I think Rock Auto is mainly OEM parts, and i'm looking to put on Stainless Braided.
Are you asserting that the ones which fit the early generation should fit (or could be retro-fitted) to the 07?
moparman76_69
moparman76_69 Dork
6/30/13 9:46 p.m.
Go to the local parts store and have them pull a 01 and a 07 and compare the two. Either that or wait until someone that has either done it successfully or has both parts laying around to compare chimes in.
EdenPrime
EdenPrime Reader
6/30/13 9:48 p.m.
In reply to moparman76_69:
Thank you. I appreciate it.
novaderrik
novaderrik UberDork
7/1/13 1:29 a.m.
go to http://www.napaonline.com/ and look them both up... save them both in the cart and compare them- are the lengths the same? fittings on both ends the same? any mounting points the same? and if anything's different, is it something that actually makes them not fit?
this all assumes that the aftermarket braided lines are made to be a direct fit repalcement for the oem hoses...
i1W5iM88QgbUdwD3vX44CLgPlAkNSw8nIBwzMtVyuBD1iu8InmwElrKvdTtYofLQ
