Login to post Forums » Sprockets » 2-stroke Megasquirt applications?
  • stroker
    March 11, 2009 6:36 p.m. stroker New Reader
    Can MS be used with 2-stroke engines? I'm thinking of ditching the carbs on my GT750 project if it can...
  • Grtechguy
    March 11, 2009 8:24 p.m. Grtechguy SuperDork
    I don't know about 2-stroke, but I believe Doc Hess did a Megasquirt to his wife's sportster
  • CrackMonkey
    March 12, 2009 8:29 a.m. CrackMonkey Reader
    I don't see why not - assuming you can find a TB and injector setup that fits, and have all the required sensors. You would also have to ensure you have enough juice to run the ECU and possibly a fuel pump (not sure if Dr Hess used a pump or not).
  • MadScientistMatt
    March 12, 2009 11:51 a.m. MadScientistMatt HalfDork
    Yes, it can. The guy you're thinking of is Andy Whittle; he favors using mass air flow sensors on 2 strokes as they don't get a very steady MAP signal.
  • skierd
    March 12, 2009 2:15 p.m. skierd Dork
    I think water buffalo's use oil-injection like the rest of the GT line, meaning the carbs only handle gasoline. That should make a MS setup a little easier.
  • therex
    March 13, 2009 8:54 p.m. therex SuperDork
    There's a link out there to a MegaSquirted RD350 or RZ350 or something.
    I'll see if I can dig it up.
  • therex
    March 13, 2009 8:59 p.m. therex SuperDork
    Found it!
    First, look here:
    http://grassrootsmotorsports.com/forum/off-topic-discussion/spockets-day-dreaming-...
    But the real meat in there is:
    http://www.rzrd500.com/phpBB2/viewtopic.php?t=1899
  • stroker
    March 14, 2009 8:21 p.m. stroker New Reader
    Cool! Thanks!
    I'll probably stick with the carbs just to get it running, but perhaps if the financial and time Gods smile upon me...
  • stroker
    March 15, 2009 8:59 a.m. stroker New Reader
    I'd never call it "useless"...
  • March 15, 2009 9:40 a.m. N1XRR
    racinginc215 wrote:
    I think the biggest concern is an injector that will spray the gas oil mix. But as I recall there was a guy on the www.MSRuns.com that was doing a sea doo 2 cylinder 2 stroke. His name was Andy White or something to that effect.
    Not a problem, RX7's do it all the time.
