The megaphones on my RD200 are NASTY. Tons of carbon buildup and nasty E36 M3 on the inside from sitting in a barn, removed from the bike for 20 some years. They look okay on the outside though. What's the best way to clean out all of the carbon buildup in these things?
March 12, 2010 1:26 p.m. SlickDizzy UltraDork
March 12, 2010 1:59 p.m. Dr. Hess PowerDork
Soilent Green, I mean Simple Green has worked for me. You could try a pressure washer as well. Or just knock anything loose out and ride it.
March 12, 2010 7:56 p.m. stuart in mn SuperDork
Are they chrome plated? If not, the old school way of cleaning them was heating them up with a torch to burn out the carbon.
March 12, 2010 8:46 p.m. SlickDizzy UltraDork
They are chrome; I fixed my moped exhaust by your method Stuart, throwing it in a campfire for a night! Came out looking like crap but free of all blockage. I don't want to torch the chrome on these though, they're surprisingly nice, but both are pretty nasty inside.
March 12, 2010 9:33 p.m. 44Dwarf HalfDork
Steps. 1) remove pipes 2) fire up the barby grill 3) place pipes on barby on med heat. 4) remove from heat about 2 minutes after they start to stink 5) hose down the inside with EZ-OFF oven cleaner. 6) place back on heat turned down to lowest setting for 5 more minute. 7) place pipes in 5 gallon pile and use garden hose. 8) leave bucket in sun to evaporite.
March 13, 2010 9:04 a.m. 914Driver UltraDork
... then steel wool it.
March 15, 2010 9:46 a.m. pilotbraden New Reader
The "red hot treatment" Works on many things
March 15, 2010 10:24 a.m. Rusnak_322 Reader
I would plug one end, fill with something like simple green and water or degreaser and let it sit overnight. Then dump out 1/2 the liquid, drop in a bunch of nuts and shake it like crazy to hopefully loosen up as much as possible. If that didn't work well enough, you can take it to a radiator shop and have it hot tanked.
