My current house has an oversized "detached" garage close to the house with a covered breezeway between. The little roof above the breezeway is a crawlspace between the two and carries electrical conduit. I bought the place in early 2003 and hadn't yet felt the need to crawl up there into the cobwebs and dust.
Last week I was storing some of my bulky, lightweight spare car parts in the rafters of the garage when something shiny caught my eye. Long story short, there was a used aftermarket 4-cylinder bike exhaust left behind in the crawlspace, and I have no idea what kind of bike it is for. Help?
It is a 4-2-1 Sudco...I have lost touch with the folks who used to live here, but I am guessing it has to be a pre-2002 bike, and likely a bit older because it was ridden, removed, and put into storage by early 2003. It is used, but not in terrible shape. Here is the brushed aluminum can:
Here you can see the construction, slip joints, exit low on the right side, no hangers or braces apparent.
And here is the flange arrangement, which seems like the most logical place to start narrowing it down:
The flange is for M8 studs, and the slots fit studs 2.2"-2.55" (56mm-65mm) apart, so the head probably uses 60mm stud spacing. Note the angles, opposite on pairs of cylinders. Viewed as above, between the exhuast port centers are as follows, left to right:
99mm or 3.9", 114mm or 4.5", 96mm-3.75" I am guessing that number one or number four was bent or warped a bit, and both the outside measurements are supposed to be the same.
The primaries have a 34mm/1.31" ID (38mm/1.5" OD) which would seem to imply a bigger four, but as a car guy, I don't know the first thing about bike tuning. It is stepped to a 45mm/1.75" OD secondary, and a 52mm/2.125" OD collector.
Any Japanese sportbike experts care to venture a guess, or at least help me narrow down engine families by exhaust stud arrangement, so I can figure out what to do with this thing?
Thanks in advance!
