Login to post Forums » Sprockets » SO MUCH junk in my gas tank. Help!
  • alex
    Nov. 13, 2011 4:59 p.m. alex SuperDork
    My TL has been laid up for way too long, which (in addition to being 13 years old) has seen the gas in the tank go bad, and rust/sediment to accumulate. It's nasty in there.
    When I worked at the shop, we had good success just using water and granulated dish soap and lots and lots of manual shaking, emptying, rinsing and repeating. I'm just concerned that the crud is too pervasive and tenacious to remove with that method.
    For the record, I'm planning to paint this tank, so if this is the time for something drastic like electromagnetic stripping majik, you'll have to hold my hand through it, but I'm receptive to the idea. So, what's your method for cleaning up really cruddy fuel tanks?
  • Grtechguy
    Nov. 13, 2011 5:05 p.m. Grtechguy SuperDork
    Yank tank.. handfull of stainless balls or nuts and atf. shake hard
  • alex
    Nov. 13, 2011 5:16 p.m. alex SuperDork
    ATF, eh? Does that have any detergent effect, or should I still wash it before or after with soap and water?
  • foxtrapper
    Nov. 13, 2011 6:17 p.m. foxtrapper SuperDork
    FIll with vinegar, let sit 2-3 day, flush and rinse with water, admire sparkly clean tank.
  • Grtechguy
    Nov. 13, 2011 6:33 p.m. Grtechguy SuperDork
    atf / seafoam....seems to strip about anything out
  • alex
    Nov. 13, 2011 6:37 p.m. alex SuperDork
    O rly? Like straight white vinegar, undiluted?
    I like 'fill and sit' versus 'fill, shake like hell, empty, repeat until you can't lift your arms.'
  • stuart in mn
    Nov. 13, 2011 6:58 p.m. stuart in mn SuperDork
    Yes, vinegar will work. I would still go ahead and clean out the big chunks first by putting in some hardware (nuts will work, or anything with some sharp edges like shingle nails) and shaking them around with hot water and soap.
    There are plenty of discussions out there about using vinegar for rust removal, with a google search you can find out the particulars.
  • Grtechguy
    Nov. 13, 2011 7:21 p.m. Grtechguy SuperDork
    or this way if you like playing with electricity.
    http://www.altelco.net/~jacil/clay/motorcycle/KElecSetup.html
  • mike
    Nov. 13, 2011 7:43 p.m. mike Reader
    Now that's interesting. I may have to try that over a weekend on some junk parts.
  • 93EXCivic
    Nov. 13, 2011 7:45 p.m. 93EXCivic SuperDork
    I have also heard milkstone solution will work. I am going to try it soon.
  • 914Driver
    Nov. 14, 2011 5:39 a.m. 914Driver SuperDork
    I've had really good luck with Eastwood's Metal Wash. It preps the metal for paint or powderdcoating. Doesn't leave a residue behind and removes schmegma.
    The little can for $10 will clean a boat load of cycle gas tanks.
    Dan
  • foxtrapper
    Nov. 15, 2011 5:15 a.m. foxtrapper SuperDork
    Mmhm. Cheapest variant you can find. No point in fru-fru types. Not only is it less physically exerting, but it simply works better too.
  • porschenut
    Dec. 29, 2011 5:13 a.m. porschenut New Reader
    I just bought a yamaha 250 with similar tank issues. Once cleaned what is the most foolproof coating if there is rust inside? Or do I just clean it and fill with fresh gas? Lucked out on this bike, the tank was left half full but they did run the carbs dry. Pulled one side and it is spotless!
  • foxtrapper
    Dec. 29, 2011 5:34 a.m. foxtrapper SuperDork
    Not a fan of coating gas tanks, I've seen a whole lot of them fail. A tank with gasoline in it doesn't rust, empty tanks do.
  • 93EXCivic
    Dec. 29, 2011 10:35 a.m. 93EXCivic SuperDork
    This. I am having the problem of getting rid of pealing coating in my tank.
  • 44Dwarf
    Dec. 29, 2011 1:33 p.m. 44Dwarf Dork
    Todays p4 gas sucks very few coating seem to last and just like paint its all in the prep work but if you got it that clean theres no need to coat it to begin with...
    Star washers and nuts work great for scraping rust out.
  • Dec. 29, 2011 6:22 p.m. mguar Reader
    Alcohol is your friend! it will soften everything. Buy a gallon of denatured alcohol at a hardware store or Home Depot etc..
  • SlickDizzy
    Dec. 30, 2011 12:46 a.m. SlickDizzy SuperDork
    mguar wrote: Alcohol is your friend! it will soften everything.
  • alex
    Dec. 30, 2011 4:23 p.m. alex SuperDork
    ^^Yep.
    Good thinking on the alcohol. I like that.
    And I, too, am not a fan of coatings for the reasons stated above. Just one more thing to cause problems. Get the tank clean by whatever means and keep it full of gas when possible. Once it's clean it will flash rust, but when it's in service it won't rust enough to cause any problems.
    But learn from my mistake: don't let it sit too long.
  • The_Jed
    Dec. 31, 2011 11:06 a.m. The_Jed Reader
    When I was a kid we always used ATF, BBs and vigorous shaking. Then we dumped the mixture into a rag, shuffled it around to remove ATF and sludge, then shot stuff.
