Login to post Forums » Sprockets » Thinking of making my own RZ350
  • airwerks
    Oct. 28, 2009 3:46 p.m. airwerks New Reader
    Tell me what you guys think.... I just sold my 02 RC51, and have an itch to do something a little different.
    I'm thinking about picking up a Kawasaki Ninja 250 frame (found an 08 with no engine / fairings but otherwise complete for $800). Add in a 2 stroke Yamaha Banshee engine ($600-800) and I think I would be well on my way towards smelling like a chainsaw.
    So far, I can't come up with any reason why a modern chassis, 250 lbs, and 45 hp wouldn't be fun.....
  • 2.0dohc
    Oct. 28, 2009 4:36 p.m. 2.0dohc New Reader
    I've thought about this, but if your going to do it you might as well use a cr500 power plant(stupid 2 stroke power with honda reliability)
  • stuart in mn
    Oct. 28, 2009 6:16 p.m. stuart in mn SuperDork
    The ultimate two stroke engine swap: http://thekneeslider.com/archives/2006/04/21/tul-aris-two-stroke-racer/ The Tularis has a 700cc, 140hp Polaris snowmobile engine.
  • MitchellC
    Oct. 28, 2009 9:56 p.m. MitchellC HalfDork
    The swap was done with an air cooled RD engine a few years back. From what I remember, it actually fit really easily; the hardest part was modifying the pipes IIRC. After a quick search, I can't find anything but a few youtube videos of it.
    http://www.youtube.com/profile?user=rooskie#p/u/36/qRk11WBCfDc
  • stroker
    Oct. 29, 2009 1:32 p.m. stroker Reader
    As long as you have a machine shop to mate the transmission that's not supplied with the Polaris it's doable.
  • airwerks
    Oct. 29, 2009 5:33 p.m. airwerks New Reader
    I'm leaning towards the banshee engine instead of a CR500 for gas mileage + you just can't beat how a 2 stroke twin sounds...
    I got rear ended a couple weeks ago and I'm pretty sure when that check comes in it will be going to getting that 08 ninja 250 frame.
  • psteav
    Oct. 29, 2009 10:48 p.m. psteav Reader
    Confusing canoe? Informative, but....wha?
  • Carson
    Oct. 29, 2009 10:58 p.m. Carson Dork
    hahaha, I know! I don't know if this canoe is evil, it's quite informative, slightly off the mark but informative.
  • Luke
    Oct. 29, 2009 11:11 p.m. Luke SuperDork
    I think if any Canoe is going to stick around, it might as well be "random chunks of useful information" guy.
  • MrJoshua
    Oct. 29, 2009 11:13 p.m. MrJoshua UltraDork
    I guess the question is: whats the catch?
  • MitchellC
    Oct. 30, 2009 1:44 a.m. MitchellC HalfDork
    I think it's supposed to be guerrilla marketing for Bing. Look! It worked!
  • sundancevette
    Oct. 30, 2009 10:30 a.m. sundancevette New Reader
    Arren is a robot. Not the computer kind of robot, but an android (like Data from Star Trek). He is the one and only true author of Wikipedia. Ask him a paradoxical question, then duck.
  • doc_speeder
    Oct. 30, 2009 11:16 p.m. doc_speeder New Reader
    This sounds like an awesome idea! Of course you know that 45 hp is pretty stock-ish for a Banshee. A good set of pipes, some decent port work and some good carbs will bump that up north of 60, and 80-85 is pretty doable (reliably) depending on your budget. A friend of mine that I ride with rides a Banshee. Lots of times I just sit at the bottom of a hill, shut my machine off, and listen to that thing wail when he's climbing. Gives me goosebumps everytime.
  • airwerks
    Oct. 31, 2009 12:45 p.m. airwerks New Reader
    I'm just hoping to get it together first.... then play with hopping it up.
    I have always wanted to learn how to fiberglass.... I think I'm going to experiment with making the fairings and such for it..... I'm thinking of theming it along an RC212v.
    Surprisingly, the fiance is all for it. She figures I just got rid of a 1000cc bike and I'm going to build a 350cc bike so it will be safer.
  • alex
    Oct. 31, 2009 12:55 p.m. alex Dork
    This really sounds like a winner of an idea. I had a customer a while back that let me ride his RG500 Gamma, and I got bit by the 2 stroke bug pretty hard. (The late '90s KX500 didn't help matters. Nor did the Kaw Mach 3.) He also recommended the Banshee motor as a good place to start, with lots of aftermarket support.
    What's your source of inspiration for this madness? Any links with good stuff for me to drool over?
  • 66healey
    Oct. 31, 2009 1:10 p.m. 66healey New Reader
    If you are going to all the trouble of a two stroke engine swap you might as well go big and try to find a RZ-500 motor. If a twin is good, a 2 stroke v-4 will be awsome.
  • Oct. 31, 2009 6:11 p.m. 93gsxturbo Reader
    I would use an older "R" (GSX-R, CBR RR, ZX-xR, R1, R6, etc) frame vs a Ninja 250. Might as well do this project in a chassis designed for 100 horsepower.
  • airwerks
    Oct. 31, 2009 11:06 p.m. airwerks New Reader
    66healey: RZ500 would be awesome... but it is hard enough to find a banshee 350 let alone a RZ350 engine... My goal for the whole project is to keep it under $2k- and an RZ350/500 engine would blow through that from what I have seen.
    Alex: The banshee engine has HUGE aftermarket support like you said, so that was the main reason. 2 stroke, twin, and I will be able to buy parts for reasonable $$ for the forseable future.
    Links? Wish there was no music on this one, but: http://www.youtube.com/watch?v=a2f0ohXy2Jc&feature=related
    And here is a pic of the 212v that I want to model the body after. I LOVE the short tail section. I will probably want to make a shorter / tighter rear hugger though. And waaaay more mild paint scheme.
    And the bike I just sold. Going to miss it.
    gsx turbo: I thought about that, but the Ninja 250 is retarded light comparable to those, and the 08' up bikes actually have a respectable chassis / brakes compared to the older ones. The thing that sold me on it, is that even though I'm going to end up with a little more power, I'm going to be dumping a BUNCH of weight. Banshee engine itself is way lighter (no valvetrain, 1/8 the cylinder head) not to mention the fact I will be ditching a battery, starter motor, electronic controls and a chunk of the wiring, the sub frame from the seat back, and having all fiberglass body work.
    How long does it take to get a check from an insurance claim!?! I'm getting antsy already! This is the first time I have ever filed a claim so I don't know how long this process usually takes.
  • benzbaron
    Nov. 1, 2009 1:08 a.m. benzbaron Reader
    45hp into a 250lb bike sounds like a winner. I just saw a ratty old vespa in Frisco yesterday and it was belching smoke like my buell blast and I think a fleet of smoky bikes is just what the city needs.
    Good idea and good luck!
  • wheelsmithy
    Nov. 7, 2009 9:35 a.m. wheelsmithy New Reader
    Hey man, I've got an '84 Kenny Roberts RZ rolling chassis I've been threatening to put a XT550 thumper in. Wanna talk trade? Check my profile for a pic(My illiteracy keeps me from posting a pic on here-sorry) I'm in TN.
  • wheelsmithy
    Nov. 7, 2009 9:54 a.m. wheelsmithy New Reader
    OH!, just saw that was an '08 ninja frame, and the prospect of a trade was kinda insulting. Unintentional, I swear.
  • confuZion3
    Nov. 8, 2009 9:55 p.m. confuZion3 SuperDork
    Did I miss something?
  • Capt Slow
    Nov. 11, 2009 2:47 p.m. Capt Slow Reader
    Yes, the Canoe cannon knocked a spambot clear out of this thread and into a different dimension, thus saving humanity.
  • motomoron
    Nov. 11, 2009 5:33 p.m. motomoron Reader
    So long as you are factoring in an infinite mount of your time for free, and don't quantify the "gains" it's a great idea.
    I've shined my ass plenty on all manner of 2 strokes (and I'm about finished putting my RD400 Daytona Special together) and I'll offer that an RZ350 has plenty of chassis for the motor or vice-versa.
    If you happen to have a Banshee motor on hand then put it in a chassis with room to grow, and with real suspension, not a weedy, built-to-a-price EX250. There's plenty of 600 chassis available cheap and they're a hoot when you dial the power back by 60%.
    Un-highside-able!
    That's why I love, love, love my KTM 690 SMC - 64 HP in a 290# bike with 120/160 DOT race tires out of the crate.
