Login to post Forums » Sprockets » Where do I find a Goldwing engine?
  • carguy123
    Nov. 1, 2009 12:00 a.m. carguy123 Dork
    I'm looking for a complete Goldwing engine and tranny for a Locost and I don't have a clue where to begin looking.
    I tried the dealers and they don't know where to send me either.
    Anyone?
  • airwerks
    Nov. 1, 2009 12:39 a.m. airwerks New Reader
    Look on ebay. I just checked and can't beleive how many of them are on there!
  • benzbaron
    Nov. 1, 2009 1:02 a.m. benzbaron Reader
    You might be able to find a complete bike for cheap then strip it for what you need and sell of the rest. I've seen some ratty ones listed for around 1000$.
  • 914Driver
    Nov. 1, 2009 7:37 a.m. 914Driver SuperDork
    oooooo purdy.
    http://dallas.craigslist.org/ftw/mcy/1443199487.html
  • carguy123
    Nov. 1, 2009 7:53 a.m. carguy123 Dork
    914Driver wrote:
    oooooo purdy.
    OK, that one is literally up the street from me so tell me why I wouldn't want to use a 1984 model in a Locost.
    Carbs are one thing, but I'd learn to live with them.
  • Grtechguy
    Nov. 1, 2009 8:31 a.m. Grtechguy UltraDork
    seems like that engine is a reverse rotation if I recall...
  • carguy123
    Nov. 1, 2009 8:36 a.m. carguy123 Dork
    It's different than later models?
    All I'm concerned about is what way the driveshaft rotates. That old a model does have shaft drive doesn't it?
  • Nov. 1, 2009 9:03 a.m. mistanfo Dork
    All production Goldwings were shaft drive from the factory. The only reason to avoid the earlier engines were due to lower displacement, and therefore, lower power.
  • xci_ed6
    Nov. 1, 2009 4:31 p.m. xci_ed6 Reader
    The carbs are a bitch, I would recommend converting to a single 4-bbl carb. On the bikes there is concern with icing, but in a car you could run a intake heating pipe off the exhaust for cold weather.
    I don't think I'd use a GL engine anyway. They are heavy (engine from my 1100 was ~300lbs), underpowered, and I know the 1100's only had 5 gears, IDK about the 1200. A sport bike engine can easily be run as a shaft drive by replacing the output sprocket with a yoke, and turning the engine 90*.
  • Tom Heath
    Nov. 1, 2009 9:27 p.m. Tom Heath Marketing / Club Coordinator
    I think the packaging and the availability of a reversing function are what make a Goldwing donor attactive to me.
  • neon4891
    Nov. 1, 2009 9:46 p.m. neon4891 UltraDork
    all wings are 5 spd. 1800's are the only factory FI models
  • xci_ed6
    Nov. 2, 2009 12:54 a.m. xci_ed6 Reader
    I check http://www.nakedgoldwings.com for my gl1100.
  • 914Driver
    Nov. 2, 2009 5:52 a.m. 914Driver SuperDork
    I'm confused, intrigued, aroused, suspicious all at once.
  • HappyAndy
    Nov. 2, 2009 7:21 a.m. HappyAndy Reader
    why not a V-Max engine? Make the fake scoops funtional and have them sticking out the top of your locost and make sure that it has a stiff frame. No need for reverse, just do a burn out to turn it 180*
  • andrave
    Nov. 2, 2009 8:56 a.m. andrave HalfDork
    IIRC the goldwing reverse is electric, not mechanical... or am I off base?
  • 44Dwarf
    Nov. 2, 2009 9:59 a.m. 44Dwarf HalfDork
    PM SENT
  • Nov. 2, 2009 8:25 p.m. mistanfo Dork
    Goldwing reverse is electric. Starter motor.
  • Tom Heath
    Nov. 3, 2009 8:43 a.m. Tom Heath Marketing / Club Coordinator
    It's more effective and reliable than some solutions.
  • 44Dwarf
    Nov. 4, 2009 8:36 a.m. 44Dwarf HalfDork
    Let me know if my contact works out for you.
    44
  • pinchvalve
    Nov. 4, 2009 11:11 a.m. pinchvalve UltraDork
    Q: Where can I find a Goldwing Engine?
    A: Sit on a Goldwing. Look between your legs. Ha Ha Ha Ha Ha!
    OK seriously, the engine in my Honda CX500 was often used as a car engine (odd British Trikes) because of its small package, shaft drive, and insane power levels. (kidding) A Goldwing motor would be an interesting motor for a similar project.
