2001 Integra LS.
Any issue with running a 200TW tires up front and all-seasons out back?
Same with brake pads: Hawk HPS 5.0 up front, OEM-replacement out back.
Not a racecar; everything else on the car would be virtually stock.
2001 Integra LS.
Why? What is your rationale behind it?
I don't see anything dangerous, but i don't see anything beneficial either
Thanks for the replies guys.
Wondering about this from a safety standpoint, for both car and driver, as well as potential performance benefit.
Car is a daily driver first, but will see just-for-fun autocross use, and to get first-time track day experience. Really just want to use this car to become a better driver and gain some good experience of driving at/near the limit, in safe environments.
Rationale is to keep costs as low, so I can get as much seat time as possible! Adds grip and brakes where the car needs it the most? Tires and brakes just seem like the most logical first "mods".
Doesn't seem like the rear pads and rear tires do much on this car. The rear pads aren't junk, just not performance-oriented. Same goes for the Michelins out back.
the brakes are fine, that's probably a good initial setup for what you're describing.
yes, you probably could get away with the tires you're talking about... but from an "education" perspective, you'd probably be better served with 4 fresh 280 or higher "max performance" tires on all four corners. that you have consistent handling, and you can swap them front-rear and get more life out of them.
the Datsaniti did challenge on some Riken for ~$80/tire and did very well on the autocross. I'd look into those to begin with.
