Zomby Woof
Zomby Woof PowerDork
12/8/13 10:03 a.m.
Ever have a bore that's a little tight, one that could use some polish, or need something for shaping a port?
This is your tool.
Take a piece of 1/4" drill rod, or quality 1/4" bolt, and cut a slot in it with a zip-cut disc.
If you need to open a bore .0005" or more, or polish it, use your die grinder, and some 400+ grit emery, and go at it, but be careful, material comes off way faster than you'd think. Great for polishing a throttle body with 220, or you can rough out a port with a carbide cuter, then finish with this tool. With 50-60 grit, you can shape and smooth a port in a matter of minutes.
SkinnyG
SkinnyG HalfDork
12/8/13 4:06 p.m.
Indeed!
I spent a ton of time doing just that on a set of heads. Roughed with carbide cutters, then smoothed with sandpaper on slotted 1/4" rod just like you show.
MLGN9d0rqjGxm4OA2D9TzFvpKt7rLu5TbsFezIg9pfApvMXH0pImXHMecqkP6Mdv
