LeGrand Mk 18 : Pre-Nationals Work for LeGrand Aug 16, 2011
In just a few short weeks, we’ll be in Nebraska for the Solo National Championships. We’re busy fiddle-farting around with some little issues that have cropped up.
We’re reworking the breather setup so that we’ll encounter fewer oil leaks and less spray from the breather tank. This involves stuffing the breather tank full of stainless scrubby (mesh) that will keep oil from sloshing around when it does get pushed up into the tank.
Next, we’re going to be changing the smaller front sprocket from 13t to a 14t to account for the fact that we’ll be running 20x9x13-inch slicks instead of our usual 22.5x10x13 meat. The reason for this change is simple: The smaller-diameter tires are lighter and, despite the named size, aren’t any narrower.
Finally, we used one of Thermo-Tec’s header blankets to prevent the heat from the header from warming up the coolant system’s expansion tank. We’ve been having some boiling issues with the tank, but we think they’re mostly due to the fact that the tank is 6 inches away from the very hot header. The temps on the gauge rarely go over 220.
No one has posted any comments yet. Perhaps you'd like to be the first?
You'll need to log in or register to comment.
