Saab 99: Halloween Stages Rally—D’oh! Oct 27, 2008
It had to happen sometime. At this weekend’s Halloween Stages Rally at the ERS Fall Festival of Speed, we suffered our first DNF. We were about halfway through the event on Stage 4 when the engine came to a screeching halt, ending our day. This was too bad, as we were doing quite well—probably mid-pack in the small field. A superficial examination told us that something was wrong with the timing chain.
After we got the car back home, we took the valve cover off and saw that the sprocket on the idler shaft was broken. This meant the entire engine had to come out. Per’s dad, Pete, helped us take the engine out that afternoon. We knew we couldn’t get the car back to the event in time to continue, but we figured that the work had to get done sometime.
With the engine out, we could pinpoint the exact cause of our DNF: The idler shaft seized and broke the sprocket. Luckily, we have most of the parts needed to fix it in our spares pile. We should have it should be back together shortly.
Comments
Jerry From LA:
Ouch! Have you figured out why the idler shaft seized? They should have no more than .005” thrust clearance. I've tossed these shafts for being out of spec.
Oct 28, 2008 12:14 p.m.
You'll need to log in or register to comment.
We were about halfway through the event on Stage 4 when the engine came to a screeching halt.
1977 Saab 99
GRM (house ad)
