May 1, 2013 update to the Porsche 911 Carrera project car
Hella Lights
Our Porsche now wears Hella headlights.
This is shown on a Miata, but this is the rather undefined beam pattern delivered by a normal 7-inch round light.
The Hellas, on the other hand, deliver a better defined pattern. The kick-up helps illuminate signs without blinding on-coming drivers.
Our Porsche, being from a simpler time, still uses 7-inch round lights. To install the Hella, simply remove the stock lamps and refit these.
We like to see where we’re going, especially at night. When our 1984 Porsche 911 Carrera blew a headlight, we took the opportunity to upgrade.
Hella offers high-performance bulbs for “old-school” standard round and square headlights. Those headlights used to be the standard, but in the ’80s we finally started to receive the “aero” headlamps that had been used in Europe for decades.
These Hella offer a better beam pattern. Instead of just spraying light everywhere, they aim it towards the pavement. A kick-up on the right helps illuminate signs and stuff.
Two flavors are available: European-spec and DOT-approved. As for which to choose, let your conscience be your guide. Your budget may play a part, too: The European lamps retail for close to $100 each, while the DOT ones cost around half that. Both will blow away the lamps sold at the local big-box store.
Our Porsche, being from a simpler time, still uses 7-inch round lights. To install the Hella, simply remove the stock lamps and refit these. The Hella’s bulb element can also be replaced, meaning it’s possible to up the wattage.
Do you like Porsches? We do, too! Subscribe now to receive 8 killer issues per year.
Comments
5/1/13 10:00 a.m.
5/1/13 6:58 p.m.
Yes, looked at them, too. They look neat, but they're also more expensive. A friend in the biz said these do just as good a job at illuminating the road.
Sponsored by
ebay
5rM8yxH1LhG3aVGquioyr0r394rzEFhi2ZddCKU606VwSuSkDUf6uvPxBiw4eGEz
