Mini Cooper: MINI Alignment Sep 21, 2005
Our H Stock MINI got its first alignment this morning. We took it to Granada Goodyear here in Ormond Beach (386-672-2251) where one of their techs took care of our special requests.
The MINI has three adjustments that can be made: front toe, rear toe and rear camber (new for 2005) We adjusted the front from .47 degrees toe-in to .14 degrees toe-out. The rear was adjusted from .12 degrees toe-in to .04 degrees toe-out. The left rear camber was reduced from -0.7 to -0.4. The right rear camber was reduced from -1.3 to -0.7. Essentially, we dialed as much negative camber OUT of the rear as we could.
These changes should make our MINI a little more “active” on course, more like some of the cars that we were watching at Nationals last week.
No one has posted any comments yet. Perhaps you'd like to be the first?
You'll need to log in or register to comment.
2005 Mini Cooper
GRM (house ad)
