Mini Cooper: MINI…on top again Mar 27, 2006
The MINI posted top index again at our CFR event, besting some decent drivers. Kim, our co-driver found the fifth spot.
We used a lower rear pressure due to a slick and gritty surface, this helped the rear stay stuck so we could power through offsets vs lifting. Our final tire pressures were 47psi front, 50psi rear.
PAX results are posted here.
No one has posted any comments yet. Perhaps you'd like to be the first?
You'll need to log in or register to comment.
2005 Mini Cooper
Saferacer
