Mini Cooper S Club Racer: Shields at Maximum May 19, 2009
Bethania Garage finished installing one of their Hard Dog roll cages in our MINI Cooper S, and recently we drove up to meet company owner Tom Beroth and pick up the car. Our timing was good, as we had to head north anyway for an April SVRA event at Roebling Road in Georgia—the midway point saved us both gas and time.
At a glance, we could tell that the newly installed Hard Dog cage was a serious piece of work. Tom and his crew had tied the cage into the MINI at several clever points, including the upper sill over the doors and rear seat posts that were just jutting out following the removal of the interior.
The majority of the tubing was powder coated, but the joints were welded in afterward—just before we were set to pick up the car. That meant we needed a coat of satin black to match the powder coating, and with so many small sections, the process of masking off the car was going to be a bear.
Armed with several old newspapers, a couple of cheap plastic drop sheets, and a fat roll of blue painters tape, we set to work protecting anything that we didn’t want covered in primer and paint. Some of the nooks and crannies around the dashboard and toward the roof of the car required delicate application of masking tape, while other areas could be covered in coarse swaths with newspaper and a quick strip of the sticky stuff.
Since we were dealing with fairly fresh bare metal, we opted to prime the paint with Rust-Oleum Clean Metal Primer. In addition to being the proper primer for the conditions, it had the added benefit of high contrast; the white paint would make it pretty obvious where we needed more black topcoat when the time came.
Our first coat of paint was black semi-gloss, and that turned out to be the wrong choice; there’s a big surface difference between semi-gloss and satin, and the powder coating was satin black. Realizing our error, it was a simple matter to grab a can of satin black and use it for the second coat. We let the first coat dry overnight and then finished it off with the satin black.
Once the second coat had dried for a few hours, we removed the masking supplies and touched up any hard-to-get areas that still showed primer. Now we’re ready to start tackling the rest of the safety gear. (Don’t forget to click on the photos at right for the photo captions and larger versions.)
Comments
Wowak:
Make it go!
May 20, 2009 12:43 a.m.
jmthunderbirdturbo:
gonna need another 60 HP to move all that steel…
May 27, 2009 7:10 a.m.
jstein77:
Not sure you have enough triangulation in there…
May 27, 2009 11:19 a.m.
You'll need to log in or register to comment.
The newly installed Hard Dog cage was a serious piece of work.
2005 Mini Cooper S Club Racer
Saferacer
In the Magazine:
