1986 Porsche 944 Turbo
Started on April 29 by caanglin
Ride Rating
0
Engine: Vitesse MAF Hallman MBC @ 15psi Weltmiester wastegate shim Test pipe Bosch 3bar FPR 83# injectors Silicone vac lines
Suspension: Weltmiester 250lb springs Koni yellows Lowered rear eccentric bolts 1.5" spacer front 2" spacer rear
Brakes: Zimmerman blanks Axxis Metal Master pads Stainless steel lines Ate super blue fluid
Interior: Personal Grinta Prosport boost gauge Escort Passport JVC head-unit
Exterior: 18x8 and 18x10 997 Turbo reps 997 Turbo front lip Red turn signals 20% tint
Misc: Venturi delete Cycling valve delete PS delete
Maintenance: Bosch plug wires Bosch plugs Fuel lines Coolant expansion tank Coolant hoses Thermostat DME temperature sensor Motor mounts Timing belt Heater valve Suspension bushings Axles
Join Free Join our community to easily find more Porsche reader's rides.
You must be registered and signed in to comment.
Subscribe Today
Learn More
OpWLvvDah6pdPmt5UqGi4p6qfMKffC6iF70P1iw3gRyfWX6JtO3TyzLOxGGRALKk
