wrenchedexcess
1997 sc1 updates:
Putting the 3.8 back together Dec 3, 2009
Got the engine sitting in the carrier and the lower motor mounts installed. The only issue so far is a 5 degree tilt toward the front of the car. Had to make some adjustments to the Fiero trans. Now starting to install the assorted brackets for the DIS ignition, altenator and power steering pump. Also getting the engine wire harness ready.
