1993 Ford Mustang LX
Started on July 19 by Lampdawgg
Original SSP 5 speed
-Full MSD ignition (distributor, cap, rotor, wires, coil, 6AL box) - BBK LT headers & shorty H pipe - Flowmaster exhaust - LX chrome tips - BBK underdrive pulleys - TFS 170 heads - ported GT40 tubular intake manifold - Comp Cams custom grind - FRPP 1.7 roller rockers - FRPP oil pump - FRPP 24 lb injectors - 75mm Pro M MAF - Accufab polished 70mm TB
Suspension - Moog bushings & sway bar links front & rear - BBK subframe connectors - Tubular control arms - 13" Cobra front brakes - Eibach front & rear sway bars - 18" anniversary cobra wheels - 265/245 tires - Eibach front & rear springs - Koni adjustable shocks & struts
Transmission - Rebuilt T5 - Rebuilt 8.8" rear end - 4.10 gears - Steeda Tri-Ax short shifter
See more:
You must be registered and signed in to comment.
